03-19-2018, 09:24 PM | #1 |
Rep 160
Will ess vt2-625 injectors work for for 650?
So I’m planning on upgrading my ess 625 kit and I currently have the white injectors that were supplied with the kit. Are these sufficient for the 650? I know pulleys, tune, etc are also needed, but wanted to see what it’s going to run me to do the upgrade. Thanks
03-20-2018, 01:30 AM | #2 | |
Rep 131
Injectors are also different and cost a lot i believe. Also the 625 kit was given different injectors though out its lifespan. So the injectors depend on when you purchased it as they are always changing the kit to make it better.
03-20-2018, 09:05 AM | #3 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
the tuner has to know what color and cc the injectors are, then tune from there. contact Benvo/BPM and he'll set you straight with questions and answers and the correct tune. i've not come across a better customer service company in the M community. the builder of the system, not so much.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
Maxf80M3174.00 |
03-20-2018, 03:36 PM | #4 |
Rep 1,326
at minimum you'll need the blue injectors.
you'll want to weigh your options here: purchase blue or black injectors (pre-machined for fitment) + 650 pulley (pre-machined) from ESS with the accompanying tune (they have different tunes based on injector size). it'll be an expensive package. OR purchase off the shelf bosch green injectors + spacers + your own 94mm pulley (will need to machine for correct offset) + green injector tune from BPM. cheaper route.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
B8bydesign689.00 |
03-20-2018, 08:54 PM | #5 | |
Rep 160
03-20-2018, 08:56 PM | #6 | |
Rep 160
03-20-2018, 09:40 PM | #7 |
Rep 1,385
I run green injectors with spacers from active for the fuel rail. And a bpm tune. No issues here. Car made 565 on pump gas with the bpm tune.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
Patrón544.50 |
03-20-2018, 10:01 PM | #8 |
Rep 1,326
03-21-2018, 07:33 AM | #9 |
Rep 1,385
8 psi pulley and a smaller belt so no slip. car made that in 80 degree weather as well. looking to do meth next.
azndrunk74613.00 |
03-21-2018, 08:25 AM | #10 |
Rep 160
[QUOTE=Properstyle;22944595]8 psi pulley and a smaller belt so no slip. car made that in 80 degree weather as well. looking to do meth
Are you using the stock crank pulley? Are you running a 94mm s/c pulley? I know some use 7 rib belt to avoid slipping but not sure if that’s necessary. |
03-21-2018, 08:28 AM | #11 |
Boost Addict
174
Rep 460
I'm running a smaller belt too, I'd love to discuss a meth setup with you .
F80 BMW M3 DCT YMB
2008 BMW E93 6MT, Ess VT2 625 |
03-21-2018, 09:08 AM | #12 |
Rep 1,385
[QUOTE=ss540i;22944768]stock crank pulley. no need to do 7 rip if you use the correct belt imo.
Patrón544.50 |
03-21-2018, 09:11 AM | #13 | |
Boost Addict
174
Rep 460
[QUOTE=Properstyle;22944947]
F80 BMW M3 DCT YMB
03-21-2018, 09:12 AM | #14 |
Rep 1,385
looking to purchase a aquiamist setup. next week.
03-21-2018, 09:14 AM | #15 |
Boost Addict
174
Rep 460
Have you dyno'ed yet for a baseline ? Who's tune will you be using ??
F80 BMW M3 DCT YMB
03-21-2018, 09:19 AM | #16 |
Rep 1,385
stated all of that above.
03-21-2018, 09:24 AM | #17 | ||
Rep 1,566
I just emailed ESS out of curiosity to see if they would provide a tune for a 94mm pulley. I suspect the answer in no as they would require the 7-rib belt system in order to provide the 650 tune, but we'll see what they say. Here's the thread I mentioned: http://www.m3post.com/forums/showthread.php?t=1435775 Quote:
http://www.m3post.com/forums/showthread.php?t=1469005
SYT_Shadow11511.00 |
03-21-2018, 09:31 AM | #18 |
Boost Addict
174
Rep 460
Didn't know bpm would tune with meth on our system ?
F80 BMW M3 DCT YMB
03-21-2018, 09:51 AM | #19 | |
Rep 1,385
Problem with your thought process. ESS will not tune any injectors larger than the blue injectors. Not sure what history are quoting as a number of cars that have been running for years are using tunes out side of ess. longer boarder didn't debunk anything there are quite a number of others who have successfully made power after adding meth one to include 1sickm3 who made more than longer boarder as was one of the 1/4 mile record holders in a e9xm3. how you spay meth is what matters. If you are using water meth to bring down iats and you spray before the intercooler you wont' be doing anything it needs to be sprayed after the intercooler. If you are spray meth for octane you will see the increase and your car will continue to hit it's timing targets even in high heat. Lastly ess is the only place you can even get a 94mm pulley from. so why you think they wouldn't tune their own product is quite confusing to say the least.
03-21-2018, 10:59 AM | #21 | ||
Rep 1,566
I have read other people ask them for a 650 tune without the 7-rib belt system and get turned down. That is all I have to go off of until they reply to my email.
03-21-2018, 11:40 AM | #22 |
Rep 1,566
Do you know if a new tune is necessary to run the 650 boost level (94mm) if injectors are not changed? I recall reading somewhere that there other differences in the 650 tune besides just injectors.
