04-03-2018, 06:44 PM | #1 |
Rep 63
How crucial is CSF cooling package with S/C upgrade?
http://www.bimmerworld.com/Cooling/C...kaAmQeEALw_wcB
Looking to purchase an ESS 650 kit mainly for STREET use. I assume that upgraded cooling compements will only be beneficial. I do not think I will need to upgrade power steering, however is the oil/radiator/transimisson coolers worth upgrading? Thanks in advance! |
04-03-2018, 11:37 PM | #4 |
///M Powered for Life
11513
Rep 10,344
If one day you need a dct cooler upgrade -usually only for tracking- i suggest you get the do88 one.
dogbone did actual testing on it and it works well For the street you are just fine with everything stock |
04-04-2018, 01:21 PM | #5 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
I would upgrade the main heat exchanger to the larger VF unit and i'd also upgrade the radiator if possible. I had zero issues with my water tempatures but the VF exchanger goes in front of the radiator so that is why i'm recommending the upgrade. if you do go with a different exchanger, then you can upgrade the size of the oem oil cooler.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
04-04-2018, 01:28 PM | #6 | |
Rep 1,385
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
04-04-2018, 05:09 PM | #7 |
Rep 1,266
Drives: 2016 M4 GTS
What kind of temps are you guys seeing without the cooling? I noticed my temps increase a LOT when getting on it (Harrop SC Kit) compared to being N/A. I've seen the needle creep up to 255 mark when having fun on the highway.
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 |
04-04-2018, 07:39 PM | #8 |
Rep 1,385
seems pretty high. did the harrop kit cooler block the oilcooler as well?
04-13-2018, 02:35 PM | #9 |
Rep 1,266
Drives: 2016 M4 GTS
Nope, the oil cooler is still in the front factory location. The Harrop heat exchanger is behind that then comes the factory radiator.
