06-09-2008, 08:31 AM | #1 |
Rep 24
how to properly jack up Z4
Ok... what is the recommended what to get the car up in the air on jackstands. I have searched, but maybe the info is buried. This would be a great How To article.
J. |
06-09-2008, 10:58 AM | #2 |
Rep 1,689
Well.. first you start by taking off your belt and unzipping your pants.. and then you..
oh wait.. oh... OH.. you said Jack UP the car.. right... You'll notice there are 4 jack pads on all 4 corners of the car in the shape of a rectangle, your jack goes under that. Those are the safe places to jack up. As for jacking up the car and putting it on a jack stand, there's gotta be some magic trick to slide the jack stand in place of the car jack. I dunno, I usually only work on one corner of my car at a time, and I'm a dumbass and don't use a jack stand cuz I'd rather die than have a hole slammed into the underbody of my car by a jack stand and a failing jack... Although theoretically, you could jack the front of the car and raise it high enough so that a whole side of the car is up in the air, then u could lower the car onto a jack stand on the back side.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
06-09-2008, 12:49 PM | #3 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
There's a center jack point in the rear where the two support braces come together. Use that to jack up the rear axle. There's also a center jack point right smack in the middle of the front subframe cross-brace. It's a square looking protrusion from the cross-brace, and it's smack in the centerline between the two wheels. Use that to jack up the front of the car.
06-09-2008, 02:01 PM | #4 |
Rep 1,689
That's great info, The HACK.
I knew about the rear jack, but i didnt know about the centre one! This will make my future brake bleeding jobs much easier!
06-09-2008, 02:18 PM | #5 |
gone baby gone
382
Rep 1,052
Unless you've got a super long, low-profile jack, you'll never hit the front point without raising the car up a little first. I have 2 small setups consisting of a 2x4 attached to a longer 2x6 that I drive the front wheels up on just to get clearance to get my jack in there.
06-09-2008, 06:47 PM | #6 | |
Rep 1,191
I drive my car up on piece of flat wood for the front ones because regular jacks have hard time getting under the side skirt. Rear one is very close, where the bars meet in the center...I have to nudge the car upward to get the jack in if you have LOW profile jack($100+) you can jack up the car without any problem
2022 GLE 53 Coupe
06-09-2008, 07:36 PM | #7 |
1821
Rep 5,337
It's good to invest in a good floorjack. This is what I use:
http://www.drivewerks.com/catalog/Sh...ACHyd1_pg1.htm Worth every penny if you do a lot of DIY projects. I've swapped everything from suspension to headers and exhaust using this to jack. $500 isn't cheap. But it's worth it. The jack point lines up perfectly with the jack if you line up the Roundel to the jack and insert it until the handle is about 1/2 inch from the bumper. |
06-10-2008, 02:22 PM | #9 | |
Rep 1,689
My last $30 jack was in service for about roughly the same time before one day it just wouldn't lift anymore. The little jack that couldn't...
06-11-2008, 12:42 AM | #10 |
Rep 1,541
when i change my oil i run the car up on a long piece of 2 by 4 wood. thwn the jack can fit under the jack points. I jack it up and place the stands underneath.
2011.5 E92 ///M3 SSII/FR |
06-11-2008, 02:47 PM | #11 |
Rep 24
question
How do you jack it up exactly? Where are the jacking points? Do you use the side jacking points and then put jackstands under there? This is the information I am in search of.... the best way to get the stock Z4 on jackstands...
Thanks! |
06-11-2008, 07:21 PM | #12 | |
1821
Rep 5,337
That and plus given how often I use it, it's paid for itself 10X over. |
06-12-2008, 09:29 AM | #13 | |
Rep 1,191
thats why there are jack stands. it works trust me
2022 GLE 53 Coupe
06-12-2008, 09:38 AM | #14 | |
Rep 142
I'm gonna look into that jack...I can always justify good tools. BigLeo
Z4MC
Canada |
06-12-2008, 09:46 AM | #15 |
Rep 1,191
i think that jack is an overkill....go to harbor freight or sears and they have good quality low profile jack that fits even the lowest cars like ours. it's mere $150 or less
2022 GLE 53 Coupe
03-03-2009, 11:24 AM | #16 |
Rep 24
Ok... still looking for exact jacking instructions for 2003 Z4
The 2003 doesn't have the front jacking point like the M. How do people jack up their Z? I understand where to put the jack stands, but I want to know where is the best place to put the jack to get the car up in the air, then put jack stands under there.
Someone uses the front control arms as the place for the jack stands (front). Anyone with suggestions? I need help on this one! |
03-03-2009, 02:12 PM | #17 | |
http://www.dkclassifieds.com
Rep 180
Just to BMW and let the work to be done there. Is all under maintenance anyways if you got an 06 and so on. Oil change etc. all for free
www.DKClassifieds.com
03-03-2009, 05:41 PM | #18 |
Rep 413
Drives: Z4 3.0, CLS63 AMG
I picked up a low-profile jack from Northern Tool that fits under my Z easily....maybe 1-2 inches to spare. It was about $75 with tax. Best jack for the $$ IMHO. I have jack stands and I really need to get better about using them. I rarely use the stands since lately all I use the jack for are wheel changes. My factory service warranty is running out shortly on both vehicles so I'll need to start doing oil, brakes, etc...
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
03-03-2009, 05:54 PM | #19 |
Rep 413
The jack I picked up looks similar to this one although it's blue and probably a much older model...
http://www.northerntool.com/webapp/w...21?cm_vc=C5502 Here's one for $60... http://www.northerntool.com/webapp/w...ge&cm_vc=C5201
03-03-2009, 05:56 PM | #20 |
Rep 274
Drives: 2010 128i Conv.
03-04-2009, 07:04 AM | #21 |
Rep 24
ok... no help
I have read the article about the lifting point in the center and the non-lifting point. I really don't want to have to remove the support structure under the car every time I want to jack it up. Can the support structure under the car be modified to become a lifting point?
This is a 2003, no warranty left and I would think I am not the only owner with this issue. Someone must have jacked up their Z4 and have proper instructions. I have seem some vague references, but that is all. I have jacked up many other cars, but I don't want to damage this thing. Thanks J. |
03-04-2009, 11:24 PM | #22 | |
1821
Rep 5,337
http://www.realoem.com/bmw/showparts...42&hg=31&fg=05 That's part number 3 in this diagram. If you've ever taken that cross brace off, you'll notice the squarish protrusion lines up perfectly to the center of the front subframe structure (part number 1 in diagram), probably the stiffest part of the car on the front axle. Use that protrusion on the brace as the place to line up the puck on the jack. Use a rubber puck if you can. The protrusion will be crushed the first time you use a jack but don't worry. What's under that squarish looking thing is the subframe. I've jacked up my '03 Z4 3.0i hundreds of times this way. |
