XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      04-15-2018, 06:32 PM   #1
modrisco
Drives: 2012 X1
Window rolls down by itself
Hi, 2012 X1 Rear window on pass side rolls down with out switch pressed. Window lock out won't stop it from rolling down . Any ideas?
      04-16-2018, 08:43 AM   #2
interceptor428
Drives: 2013 x1 28i/2015 428 m sport
have you checked your switches? sounds like something spilled into your switch and maybe caused a short on the close circuit. How do you get the window back up? are you using the switch on the door in question or the driver control switch?
      04-16-2018, 11:17 AM   #3
modrisco
Drives: 2012 X1
Switch
Thanks for the reply. have not spilled on the switches. This has happened before but usually roll up the window and it stays up. This time on a 20 min drive window rolled down 6 times. On way home it didnt roll down. Using switch on drivers door to roll up.
      04-16-2018, 03:07 PM   #4
interceptor428
Maybe your battery is on the way out...I'm just thinking out loud; I have no real solutions sorry
      04-17-2018, 04:17 PM   #5
kiloTHREE
Drives: '13 xDrive28i
Pulled any codes?
Originally Posted by PrematureApex View Post
What a jackass...
      04-18-2018, 01:12 PM   #6
modrisco
Drives: 2012 X1
No lights on to indicate codes. I could try and see if anything comes up. Thanks.
      04-29-2018, 07:30 AM   #7
12 Handicap
12 Handicap's Avatar
Drives: 2013 X1 S28 I
Perform an exorcism, thinking outside the box.
      05-03-2018, 05:16 PM   #8
BeeHemDoubleU IksWane
BeeHemDoubleU IksWane's Avatar
16
Drives: BMW X1
The actuator is bad. At least in my case it was. Same symptoms too, but rear driver side
You talk about German technocracy and you get automobiles.
xbimmers
