Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      06-15-2018, 11:56 AM   #1
FormulaMMM
FormulaMMM's Avatar
Drives: E90 M3
Alignment/negative camber question
Is the consensus that there isn't much (if any) negative camber to be gained with an alignment? Anyone get a worthwhile adjustment in stock form?
Going to have the car set to track height. I'll bypass the alignment if it's essentially maxed out from the factory.
Thanks
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
      06-16-2018, 06:30 PM   #2
M4_GTS
Hong Kong
1153
Drives: M4 GTS
the front is pretty much fixed with no adjustment from the factory, but the rear you can adjust.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      06-19-2018, 12:25 PM   #3
FormulaMMM
FormulaMMM's Avatar
Drives: E90 M3
Thanks for the feedback. Bummer. I'll probably put it on the rack anyways to see where I am before lowering, check with the techs on potential adjustability.
f80post
