06-19-2008, 08:43 PM | #1 |
Rep 1,035
Stoptech's First BBK for E92 M3
I spent a long time shopping and trying to decide which kit to get for my M3. I gave a call to Stoptech one day and talked to Howard. Next thing you know, I scheduled an appointment this past Tuesday to have the kit installed.
I arrived at the facility in Compton where they have a huge building and several CNCs and other manufacturing equipment. They make their own stuff, those rumors about them using someone else's calipers are incorrect. They OEM a lot of stuff, they make the kits for a lot of these aftermarket companies (one of which I cannot mention by name but all of us BMW folks know who they are). I was surprised to know about some of the stuff they are turning out. They even have their own dyno where they stress the products to do pre-TUV testing before they send it off to Germany. It was cool to see that machine go. Stoptech had already taken measurements of the E92 M3 in Europe. My car would be the first car which the kit would be installed on. One really nice thing about Stoptech is they have a wider range of rotor combinations than the other companies. For example, their 6 piston calipers have more different combinations of piston sizes so they can customize the caliper to the application more than the other companies. My car was driven and tested by the engineers and this is what they came up with. 380x35 front rotor, 355x32 rotors on the rear. ST60 6 piston calipers for the front, ST40 4 piston calipers for the rear. PFC1038 pads for the front, Axxis ULT pads rear. The pads are high performance street pads which also minimize dust. I asked for the cross-drilled option on the rotors (they won't crack as Stoptech has eliminated that by using a special pattern), black hats, black calipers, and zinc coated rotors. Weight is as follows: Front 380x35 DRILLED disc + 37.160.D613(hat) + hardware ~22.01 lbs ST60 w/ pads & bracket ~13.11 lbs Rear 355x32 DRILLED disc + 37.160.7425(hat + hardware ~19.33 lbs ST40 w/ pads & bracket ~11.145 lbs The car no longer has that strong initial "amplification" as their engineering manager Steve calls it. That artificially strong bite at the beginning is gone. The pedal feels more natural and sits just a tad higher. I couldn't be happier. They bedded the brake pads in for me. The car feels faster as there is a good weight savings. So here's how it all looks and you can see the car at Spocom on Sunday at the KW booth. Big thanks to Howard and Steve at Stoptech. Sorry the car's a bit dirty in the pix.
06-19-2008, 09:50 PM | #2 |
M4 CSL FBG
1270
Rep 1,871
nice pics congrats. Did they have pricing yet?
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World 08' E92 M3 Jerez Black |
06-19-2008, 10:27 PM | #3 |
Rep 10,407
Nice, looking really good. By the way we had this "debate" already. You can not feel 20 lb of weight on a car with ~400 hp and ~3700 lb, even if it is rotating. Last but not least - pricing please!
06-19-2008, 10:59 PM | #4 | |
Rep 1,035
I'm going to use an educated guess here and say configured as I chose with drilled rotors and zinc coating just under $6200. Definitely give Stoptech a call if you are interested.
06-20-2008, 03:33 AM | #5 |
我的車車有Turbo&!!!
152
Rep 2,599
Drives: 빠른차
very very very very nice
06-21-2008, 01:43 AM | #6 | |
Rep 10,407
Car still looks killer, JMHO above. |
06-21-2008, 10:41 AM | #7 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
I've always thought the Stoptech logos to be very distracting.
Otherwise, they look nice and I bet work well, hopefully they offer their kits w/o a logo. |
06-23-2008, 05:54 PM | #9 | |
Rep 1,035
Stoptech 380x35 (F) 355x32 (R) Brembo 380x34 (F) 380x28 (R)
06-24-2008, 04:12 PM | #10 | |
Rep 1,920
As for the logo, I also did not like it. Being as the caliper is powdercoated, and the logo is painted on, all I had to do was take a rag and a bit of carb cleaner and wipe off the logos! Then I had nice red calipers on there with no BIG ASS logo on them! If I go BBK with the new M, I will almost certainly go with StopTech. Wonderful company and product!
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
06-26-2008, 01:20 PM | #11 | |
Ground Pilot
41
Rep 548
Drives: e92 BMW M3
Maybe, if I got lucky and found a wrecked M3 that had Brembos and could buy them for pennies on the dollar, then I would go for it. But if I thought that was realistic, I would play the lottery.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
06-26-2008, 01:50 PM | #12 |
BimmerPost Supporting Vendor
9599
Rep 10,891
The stoptechs look fantastic!!
Have you driven aggressively on these yet? How's the fade?
06-26-2008, 02:47 PM | #13 |
Rep 644
It will be interesting to see a comparison test between the BBK kits and the stock brakes.... I think the standard 60-70-80 to zero test only once....there won't be much of a difference....only on the track after repeated hard braking will the BBK's start to show improvement over the stock brakes...but for a street car....its not worth it.... but the BBK's sure look better!
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded! 1988 Porsche 928S4, Guards red/Champagne leather 1989 Porsche 928S4 track beast!!! |
06-26-2008, 03:42 PM | #14 |
Rep 1,035
No I have not. I haven't had much time with the car since the brakes were installed but you can expect that this system performs as the other Stoptech systems do with the ST60 and ST40 setup which is excellent. The most aggressive braking performed was during the bedding process and fade was minimal. I have to get some 19" wheels for the track, these 25 series tires are like rubber bands....
06-26-2008, 11:33 PM | #15 | |
Dr. Octagon
260
Rep 1,919
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
06-27-2008, 03:43 AM | #16 | ||
Rep 1,035
06-27-2008, 09:04 AM | #17 | |
Dr. Octagon
260
Rep 1,919
lucid: Can you fix?
OC ///M
09-14-2008, 04:34 AM | #18 |
Rep 1,035
Updating this information since I re-weighed the stock brakes.
OEM Front Rotor ____Brembo ______StopTech 22.7 Lbs ___________24.8 Lbs ____22.01 Lbs OEM Front Calipers _Brembo ______StopTech 14.5 Lbs ___________13.0 Lbs ____13.11 Lbs OEM Rear Rotor _____Brembo ______StopTech 19.7 Lbs ___________17.0 Lbs ____19.33 Lbs OEM Rear Calipers __Brembo ______StopTech 11 Lbs ___________9.6 Lbs _____11.145 Lbs OEM Weight Front ___Brembo ______StopTech 37.2 Lbs ___________37.8 Lbs ____35.12 Lbs OEM Weight Rear ____Brembo ______StopTech 30.7 Lbs ___________26.6 Lbs ____30.475 Lbs OEM Total Weight ___Brembo ______StopTech 67.9 Lbs ___________64.4 Lbs ____65.595 Lbs
09-14-2008, 10:18 AM | #19 |
Rep 1,297
Does Brembo have an M3 specific BBK? Because the last time I phoned them about a month ago, they told me they do not have it. sorry if this has been asked or mentioned before!
Cheers! Btw, the Stoptech brakes look sweet on your ride! |
09-14-2008, 03:46 PM | #20 | |
Rep 2,244
09-22-2008, 06:36 PM | #21 |
Rep 436
Stopping will be better, brake fade will also be better.
Arsenal F.C. - Gooner 4 Life
01-19-2009, 11:39 PM | #22 |
Rep 1,035
Updating again since the chart didn't take 4 corners into the equation... (how could you PencilGeek???) Note that we still need exact figures for the Brembo kit.
OEM Front Rotor ____Brembo ______StopTech 22.7 Lbs ___________24.8 Lbs ____22.01 Lbs OEM Front Calipers _Brembo ______StopTech 14.5 Lbs ___________13.0 Lbs ____13.11 Lbs OEM Rear Rotor _____Brembo ______StopTech 19.7 Lbs ___________17.0 Lbs ____19.33 Lbs OEM Rear Calipers __Brembo ______StopTech 11 Lbs ___________9.6 Lbs ______11.145 Lbs OEM Weight Front ___Brembo ______StopTech 37.2 Lbs ___________37.8 Lbs ____35.12 Lbs OEM Weight Rear ____Brembo ______StopTech 30.7 Lbs ___________26.6 Lbs ____30.475 Lbs OEM Total Weight ___Brembo ______StopTech 135.8 Lbs __________128.8 Lbs ____131.19 Lbs
