06-26-2018, 05:16 AM | #1 |
Rep 43
Fan / Blower motor stopped working !!
My blower fan suddenly died ? The climate control panel gives full indication of fan speeds and on and off but no response from blower motor!!
I have checked my Blower fan works on its own when supplied externally with 12V through an external Car Battery. My RESISTOR ( endstage resistor ) also works as I took out and swapped with my wife's car. It works . Also swapped my Climate control unit IHKA with my other car. WORKS... All the rest of the buttons on Climate control work. The fan speed display is fine.... The 12V + supply is going to the RESISTOR module. Both positive and Negative.... The Car Battery has 12.2 Volts coming to the RESISTOR unit under the blower fan when the car has no ignition. Could some one please HELP....... |
06-26-2018, 10:48 AM | #3 |
Rep 341
I was disconnecting the fan controls (the module with the temp controls on each side) one day fishing some cable up through there and re-plugged them when I was finished and the fan was not working...so I disconnected them again and reconnected them securely and the fan worked fine...if you did that maybe unplug and re-plug them again?
Metallic Black on Black 2009 135i, new waterpump, OFHGs, and VC gasket...RB turbo PCV valve (ooo), NGK performance plugs...V3Cobb access port stage 2+FMIC, Injen intake, Mishimoto clone FMIC, ARM charge pipe, ARM downpipes, Whiteline subframe bushings
06-27-2018, 07:07 AM | #5 |
Rep 43
I have located the third wire (White with brown line ) going into the endstage resistor socket along with +B (Red with stripe) and Negative wire ( Solid Brown).
This third wire , thin , is the reason for non functional fan. I did some digging and found on the forums some guy saying that the blower fan and it's speed control works through a PWM signal. So that simply means one thing ( since the +B 12V and earth are ALL TIME ON ) that the thin White wire with brown stripe is the wire controlling the Fan / Blower motor ( ON/OFF & Speed) Compared and contrasted that wires supply voltage ( as I only have a multimeter and no oscilloscope) With my wife's BMW 3 series E90. That wire gives Negative supply ( goes low when fan is turned on ) and slides the scale 0.01V up with every step up of fan speed Mine was not going low ( negative supply / earth ) Turned out , the same cable ( White / Brown stripe ) comes out from the black socket on the back of climate control panel. The one displaying speed and temperature and AC controls That wire upon checking did give me a low / negative with step up 0.01V with every click of fan speed !!! SO IT SEEMS LIKE A HARNESS FAILURE TO ME. THAT WIRE IS BROKEN SOMEWHERE IN ITS PATH. I have put a bypass cable to have the PWM restored and Was DELIGHTED TO SEE MY FAN / BLOWER COME BACK TO LIFE !!!!! Thanks to everyone for contributing. I would welcome any comments about what I did , right or wrong ? |
01-06-2024, 09:41 PM | #7 |
Rep 271
Interesting. I wonder where the break is? Is your car garaged or exposed to elements at night?
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
01-19-2024, 07:48 PM | #9 | |
Rep 3,924
Drives: 330i, 135i
