06-26-2018, 03:09 PM | #1 |
Rep 24
*WEIRD NOISE in my BMW 640i 2016 \ F06 HELP* video provided
Hi guys it's my first time in this website I hope it will be a great experience
I have 640i\f06 after I wash it with water usually a weird sound come from between the engine and the front left tire and since I bought it 2016 I took it to the dealership like 1000 time ,but they don't know what's the issue any suggestions , or some had the some issue this is a video so. you can see. Last edited by suliman; 06-26-2018 at 03:27 PM.. Reason: I want a bold title but I don’t know how |
06-26-2018, 05:23 PM | #2 |
Rep 2,926
Wow, that is one of the weirdest noises I have ever heard car make. The dealer cannot tell where that is coming from? How long does it take to go away after you wash it? Does it occur from just washing the outside, or do you spray off the engine?
06-26-2018, 07:17 PM | #3 | |
Rep 303
Drives: 2017 BMW X5M
06-26-2018, 07:34 PM | #4 |
Rep 24
It occurs after washing just the out side since day 1
06-26-2018, 07:38 PM | #5 |
Rep 24
It usually stays about an hour
06-26-2018, 10:12 PM | #6 |
Rep 2,926
Since I don't have a 640, I can't look at what is located over there. Does it matter if the engine is hot or cold before you wash the car? I was thinking that maybe the water is cooling a metal part, and causing it to shrink and break some seal. But that would not make any sense if it squeals like that at startup even if the engine is dead cold. Also, it does not seem like it would take an hour for a part to get hot again.
I'm still very curious about this happening if you wash only the exterior of the car. That would lead me to try a process of elimination. For example, does it do it if you wash the car as normal, but wash only the back half? Seriously. If that does not do anything, then try washing the whole car, but be careful to eliminate spraying water in a certain location each time. On separate occasions, don't spray (1) at the base of the windshield by the wipers, (2) in the wheel wells, (3) the wheels themselves, (4) into the grill, (5) under the car. I cannot believe that getting only the exterior paint wet is causing it, so water is getting on something internal. If you can figure out what entry point makes a difference, you can probably start to track it down. The base of the windshield seems like a likely culprit to me. I might try that first. Avoid spraying there, and even stuff towels into the gap to catch any that might get in. EDIT: And I was going to ask if it happens in the rain, but I see you live in Saudi Arabia, so never mind. Last edited by Opie55; 06-26-2018 at 10:19 PM.. |
06-26-2018, 11:14 PM | #8 | |
Rep 24
Actually about your point that if I washed just some parts , the sound starts after washing the front left rim with plenty of water |
06-26-2018, 11:18 PM | #9 |
Rep 24
06-27-2018, 12:51 AM | #10 |
Rep 2,926
A non-running car makes that noise???? Well now I am stumped. But if it is not running, how they heck can the dealer not tell where it is coming from? Usually it is all the sounds from a running engine that can mask where noise is coming from.
06-29-2018, 10:35 AM | #11 |
Rep 127
Hi, I see that this guy experienced something similar. However his car was on when it made the similar sound after washing and turns out to be the belt of his ac compressor pully. Otherwise, would it possibly be your front left brakes? I'm just roughly piecing together cold water + hot metal(?)
Hope it might help link: http://www.rs25.com/forums/f13/t1538...eo-inside.html |
Tags |
https://youtu.be/okzd2bp52zi |
