08-08-2018, 07:43 PM | #1 |
Rep 466
Need to borrow a injector seal toolkit
As the title says, I'm buying some used injectors and they need new seals. Does anyone in here have the toolkit for removing and replacing the seals with the compression rings ?
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV |
08-09-2018, 05:45 AM | #2 |
Rep 2,028
08-09-2018, 07:52 AM | #3 |
Rep 466
08-09-2018, 07:55 AM | #4 |
Rep 2,028
How soon do you need it? I have one I am still using right now. Still putting my motor back together. I'd have to mail it which would take a few days (Long island) once I am done with it (another week or so).
This is the schwaben tool for replacing the seals... not the puller tool. |
08-09-2018, 07:59 AM | #5 |
Rep 466
I have an injector puller, just need the tool for removing the old seal, putting the new one on then the "resizing" rings. I can wait.
Maybe you know the answer to this : I plan to flash MHD 2+, have catless DP, BOV, FMIC upgrade. If I flash it I read that this is where problems are exposed, weaknesses. Assuming I flash it, what is the worst thing that will happen ? Multiple misfires under WOT ? Can it be driven "calmly" until I get the issues fixed ? Or....can I just flash it back to stock and the problems hide again or is the damage done per se. Any idea ?
08-10-2018, 09:37 AM | #6 | |
Rep 2,028
If any of those items are worn badly then asking them to do more may result in the tune not running well. Plugs and coils are maintenance items. However, you don't just go replacing parts on a car unless something is wrong or is really convenient at the time to save labor. Unless of course you like throwing money away... Flash the tune and get some good logs. Use the logs/codes to determine what you need to do and not ask people on forums lol. If you are asking for an injector tool then I am guessing you already have some codes or an on-going issue and I'd personally take care of that before trying to make more power. Last edited by bbnks2; 08-10-2018 at 11:56 AM.. |
08-13-2018, 09:53 AM | #7 | |
Rep 466
