08-20-2018, 02:52 PM | #1 |
Rep 21
Rear Tires Rubbing Fender Liners
Hey all. So I've tried to do some research but haven't come to any clear answers so forgive me if this is a repeated question.
So I recently had my 35is dropped onto H&R springs but kept the stock style 326 wheels. I've got stock sized Michelin Pilot 4s tires and am running 10mm spacers on the back. That would put the rear offset to 30 which I know is aggressive for our cars but I saw some people running even more aggressive offsets thus concluding I should clear.... well I don't and i'm rubbing on the edge of the outer plastic fender linings above the wheel. Any suggestions on how to modify the liners? Is cutting ok? If so any suggestions on the best way to go about it? Thanks for the help!
Current: 2013 Z4 sdrive35is MHD 2+ E50 OTS Tune, Wagner EVO 1 Comp FMIC, ER CP, Tial BOV, VRSF CLDPs, E9X Control Arms, H&R Springs, H&R Sways, Turner Rear Camber Arms, M Performance BBK, BBS CH-R wheels, Stubby, CeramicPro, Late Side-markers, Michelin Pilot 4s
Past: 1995 840ci Calypso Red/grey w/a bunch of modz |
08-20-2018, 06:24 PM | #2 | |
Rep 193
08-20-2018, 08:20 PM | #4 |
Rep 561
Mine have rubbed for 7k miles, most of it on H&R (now on Ohlins). Anyway ... it's not a problem. Why cut? It will wear about 10" of the plastic arch and that's it. Doesn't hurt anything.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport. |
08-20-2018, 08:27 PM | #5 |
Rep 745
Speaking once again of the obvious, wouldn't that be an entry point for unwanted moisture in rainy weather?
08-21-2018, 07:56 AM | #6 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
08-21-2018, 05:47 PM | #7 |
Rep 21
Thanks for the responses guys. Obviously pulling off the spacers would do the trick, but I love how it's sitting right now. I may just trim some of the plastic fender liner away with an exacto-knife. It's not hurting anything but man is it annoying. It doesn't rub often but it just makes me cringe every time it does.
08-21-2018, 07:02 PM | #8 | |
Rep 561
Filippo
08-21-2018, 07:51 PM | #9 |
Rep 21
So it sounds like the plastic liner is more cosmetic than anything else? Sure sticks out far and gets in the way!
08-22-2018, 12:08 AM | #10 |
Rep 561
It's not cosmetic. It serves a few functions like every inner fender liner on most cars made. The liner does stick out a bit on the top, but regardless the tire can wear all the way through. I've had several cars where this has occurred with larger wheel/tire setups and suspension changes. I've never had any issue whatsoever. On the Z4 I have it as well, and as I said, it has no bearing on anything. In fact I've pulled liners out of the car twice doing work in the fender well - the liner is completely intact, just with a section worn through at the top.
That said, $10 gets you a set of 5mm spacers, and this becomes a non-conversation :-). Filippo
08-22-2018, 01:12 PM | #11 |
Rep 906
Let it go. Soon you will have a custom fit liner that fits perfectly to your setup.
08-22-2018, 08:16 PM | #12 |
Rep 745
Whoa; Let's back the truck up a bit Filippo! Your logic here totally evades me. I just looked under the rear of my 2013 and the only "unsealed" part of the inner fender liner I saw was the cutout for the damper on the inner wall. My guess is that this area is open at the bottom and any water/that gets slung into that recess is free to drain down the frame and exit the bottom of the car. The outer edge of the liner is an entirely different matter. It's a boxed design that rests against the inner edge of the wheel arch. Water slung up against an intact liner simply rolls down the underside of the liner onto the ground. start punching holes with the outer edge of a tire and water flung up to that area is free to pass through the abraded hole and migrate down the top side of the liner and collect in the junction where it meets the sheet metal of the fender arch. This is a perfect invitation for rust to start as it does on many older vehicles. I would think you would know this being as car-savy as you appear to be!
08-22-2018, 08:26 PM | #13 |
Rep 561
The metal is not raw nor multi-point welded. I've never had a car rust because the plastic liner was not sealed. But that said, one should certainly do what one is comfortable with, given their own logic and experience.
Filippo
08-26-2018, 07:04 PM | #15 | |
Rep 561
Filippo
08-30-2018, 12:49 AM | #16 |
Rep 153
09-24-2018, 08:01 PM | #17 | |
Rep 41
I'm running 285/20" and have minor rubbing wear on the outer edge of the liner so if I can push that edge out more to the fender that would be great! Any pics? Thanks! |
