08-26-2018, 12:25 AM | #1 |
Rep 148
Rubbing, humming, vibration noise from rear
Getting a slight high pitched humming/rubbing noise but only from 750-1000 rpms at slow speeds accelerating and turns. At times I can feel/ hear vibration coming from the rear. Happens intermittent too! Want to take it in before warranty is up. any ideas?
Car has CCB and is DCT could it be brakes? Differential? |
08-26-2018, 06:05 AM | #2 |
Rep 4,823
You should get it checked if not sure what it is, but sounds like it may be the CCBs. I had them on my 2015 and they can be noisy, including the rubbing-like noise you described. You'll find some threads here about CCBs, including CCB noise:
https://f80.bimmerpost.com/forums/fo...play.php?f=532.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
08-26-2018, 02:49 PM | #3 |
Rep 3,738
Drives: 2016 M4 DCT Tanzanite/Amaro
If I may: how many miles are on your car and has the diff fluid been changed other than at the 1200m service?
08-26-2018, 05:38 PM | #4 |
Rep 148
08-26-2018, 06:39 PM | #5 |
Rep 3,738
Assuming you mean "....since the 1200m service" then it's not a diff maintenance issue. I don't have CCB so I can't speak to that although there do seem to be stories about various CCB noises. My first concern would be the diff regardless of maintenance history, and I'd be off to the dealer. If it's the sort of sound you could record on your phone, then I would do that. Good luck.
09-03-2018, 06:48 AM | #7 |
Rep 4,823
Did they identify the source?
09-11-2018, 03:01 PM | #8 |
Rep 22
Not certain about what you're hearing, but aren't these diffs equipped with electronically controlled clutch plates? I often hear them "groaning" under power when not in a straight line- like what you've described. I would guess what you're hearing is the differential doing its thing and is an expected and normal noise.
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
'15 M3 6MT MetGrey 19s: hull strike 2018 2018 M3 TanzBlue DCT |
