09-09-2018, 01:04 PM | #1 |
Rep 53
EGR valve
Just helping some of us when iDrive show engine error and invite you to drive slowly...:mad0260
https://www.newtis.info/tisv2/a/en/f...check/Fli3JfLD It simple comes from this mechanism that must be lubricate with a sliding grease.
bmw f15 3.0d 2018
bmw e90 320d 2006_2018 bmw e36 318is 1996_2006 |
09-09-2018, 05:08 PM | #2 | |
Rep 570
In case somebody needs to replace theirs, this EGR cooler and Valve/Actuator only has a few thousand miles on it... EGR Cooler and Valve/Actuator https://f15.bimmerpost.com/forums/sh....php?t=1531245 |
09-10-2018, 02:25 AM | #4 |
Rep 1,270
There is a global recall on EGR Valve Cooler, possibly related to the recent incidents in South Korea, where BMWs caught fire.
Better check with your dealer. |
09-10-2018, 10:04 AM | #5 |
Rep 570
Could you possibly post a picture of the letter for those that did not get one of these letters, so once somebody has an issue they could take it with them to the dealer?
09-10-2018, 01:17 PM | #6 |
Rep 847
09-10-2018, 08:00 PM | #8 |
Rep 847
Here they are (all three pages):
https://photos.app.goo.gl/szYpWNqLVWZ3wntV9 https://photos.app.goo.gl/feJsdyV95hi3yWGD9 https://photos.app.goo.gl/BFDdD9oEFwacP2JU8 |
09-12-2018, 04:14 PM | #10 |
Rep 53
thank you, i have 60.000 km but made 7000km in one month and think that the grease on the mecanisme that open and close the valve was disapear of the heat...put some and will answer you if the message will appear again...
bmw f15 3.0d 2018
09-13-2018, 12:39 AM | #11 |
Rep 103
Did you check the error code using Carly, Bimmerlink or something similar? I had the following error but no CEL:
255C00: Exhaust gas recirculation control, position control: valve too open / negative control deviation Had the EGR valve replaced yesterday under warranty. 30 000 km. Only symptom was loss of power. |
09-17-2018, 08:18 AM | #12 |
Rep 53
there is no error code appear with bimmerlink, but definitly it comes from here. Put the sliding grease and since 4 days there is no more error Think this error appear and disapear when the valve is blocked or stay open all the time until its deblock himself.
bmw f15 3.0d 2018
MrTookies459.00 |
09-18-2018, 12:53 AM | #13 |
Rep 103
My dealer replaced the EGR, it was covered by warranty. Unfortunately there are still 3 lambda errors left that they did not solve. I told the dealer about the error i found with Bimmerlink and he told me that as long as the car has no symptoms and no CEL, i should be fine. I am afraid there is another EGR replacement incoming.
