09-18-2018, 12:26 PM | #1 |
Rep 563
Will I rub? 666m with spacers
Ordering emmotion lowering springs for my m4
I have 295/30/20 rear and 255/30/20 in the front, if I put 15mm spacers and drop the car will it rub? Any input would help a lot. |
09-18-2018, 01:29 PM | #2 |
Rep 327
I have 1.3" drop in front and .8" drop in back and I rub very slightly with stock 245/275 tires on 666m under heavy load. 12mm front and 15mm rear spacers.
JamesF80m3265.50 |
09-18-2018, 06:54 PM | #3 |
Rep 1,481
HarrisonK Why are you running 255/30/20 and not 265/30/20? OEM is 265/30/20 PSS Star Spec. To answer your question, no you won't rub. I ran 255/30/20 MPSS on 20x9 et8 which is equivalent to running a 21mm spacer on your car. When I wasn't dropped however, I did rub on full lock on the inner liners, not a big deal at all. The rear may or may not rub depending on your camber specs. with 295/30/20 you might want to just try 10mm.
Smeargle which stock tires are 245/275 on 666m? Nothing ever came in those sizes. |
09-18-2018, 07:45 PM | #4 | |
Rep 327
09-18-2018, 11:27 PM | #5 | |
Rep 563
09-20-2018, 12:51 AM | #6 |
Rep 438
Eibach Pro kit. 666M. 265f/285r. 10mm all round. ABSOLUTELY no rubbing at anytime. Not sure about 15mm tho
