09-19-2018, 10:21 AM | #1 |
Rep 112
Drives: 2015 X5M
Best Price For Stage 1 Dinantronics Tuner (F85)?
For those of you that live in SoCal and run a Dinantronics tuner on your F85/F86, where did you purchase yours and how was the experience?
I'm in the process of comparing different shops/vendors to see where I can get the best deal on the Dinantronics Stage 1. IIRC, at least one shop near LA had them a few hundred dollars below standard MSRP and with a 7 day satisfaction policy...hopefully I will be able to find their contact info. Anyway, i would very much appreciate any input - both the good and bad - so I can decide where to get it done. Thanks in advance! A. PS. I am in Santa Barbara, so the closer to that area the better. Though getting it done in LA/OC is possible if it is worth the added drive... |
10-03-2018, 10:28 PM | #4 |
Rep 94
I might be interested in the used Dinan Stage 1.
I was under the impression that they aren't as simple as plug and play. I had thought that Dinan needed the serial numbers to match to the install and also not sure if their warranty is transferable etc. If its not what the advantage would be over a BMS Stage 1 (since outside of that they are identical in their performance improvement? |
10-23-2018, 01:15 PM | #5 |
Rep 107
Drives: 2022 X5M Comp
Anyone ever get an answer for this one?
2022 Marina Bay Blue X5M Competition |
