10-03-2018, 09:11 PM | #1 |
Rep 131
Powder coating brakes calipers...
I've done a bit of reading on painting vs. Powder coating. I think I'm leaning towards powder coating due to the fact that I can't find anyone locally in southern Idaho that will paint them (and they seem to look better imo). I know some people do it themselves, but I've watched enough how-to videos to know that I'm not comfortable doing this myself (caliper disassembly, powder coating or painting).
My question is - my local powder coating company has quoted me $500 to fully clean, file down and powder coat all 4 calipers. They work with a foreign car repair shop that does the removal of the break calipers, stores the car while the powder coating is happening and then they reassemble with new gaskets/seals and warranty their work. Unfortunately they charge $700 including the parts to do this. That brings the total to $1200. That seems pretty high to me, but from what I've seen on YouTube this is a pretty involved process and as I'm not car mechanically inclined having a guarantee/warranty for the work is a must. Is this way out of line for this, or in the ballpark? Thanks for taking the time to read! |
10-03-2018, 10:25 PM | #3 | |
Rep 131
The quote I was given was more than I thought it would be but if it is fair then I will have to bite the bullet and get it done! Thanks again! |
10-04-2018, 03:07 AM | #4 | |
Problem Solver
113
Rep 417
Proper meaning- removal, cleaning and re-install, coat or paint. I have had my brakes painted for years using various methods. It can run from a $10 up to a $2000 job depending on how fancy you want to go. I would say decide on how long and how you want them to be that color, it is definitely and investment though... a good one no matter what route you choose.
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". |
Vorpel47.00 |
10-04-2018, 06:01 AM | #5 | ||
Rep 131
10-04-2018, 04:17 PM | #6 |
Rep 709
I have not input for the costs but the cleaning is mandatory in any case. I have painted my caliper several times (different cars) with different products. For normal good job I would go for the brush 2C system. In my cases it was a high gloss red/ blue and black. When the wheel is mounted you can’t see the difference between painted by a pro / powder coated or brushed by diy. Before I spend 1200$+ for colored calipers......
Vorpel47.00 |
10-04-2018, 04:48 PM | #7 |
Rep 742
I think you meant the G2 paint product.
Google: G2 High Temperature Brake Caliper Paint System Used it on two Corvettes and it looked very good. It's a 2 part epoxy paint that when brushed on smooths out by itself eliminating "brush" marks. Here is what I said on a Corvette site: Not only is the G2 kit a hardening epoxy paint, it's also high temp made for brake calipers. These were done three years ago and look like the day I did them. Just buy a set of small artist brushes instead of the useless one that comes with the kit. I did mine without removing the calipers from the car. Mix half the paint and do two and then mix the rest and do the other two. I bought two kits but think you could probably do it with one. [IMG][/IMG] |
Havy304.00 |
10-04-2018, 04:52 PM | #8 | |
Rep 131
10-23-2018, 12:36 PM | #11 | |
Rep 131
10-23-2018, 01:17 PM | #13 |
Rep 131
Lol - will do. Pics are in another thread but why not add them here as well...!
