BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BPM
      07-07-2008, 07:42 PM   #1
Gemcoska
Sleepy Member, wishing I was on the road.
Gemcoska's Avatar
34
Drives: 2008 BMW M3
Brake fluid reservior not same as power steering
So I decided to upgrade my brake fluid to RBF600 so that I could avoid boiling my brake fluid on the track.
So Problem 1, where are the center jack points!! Some research locates the front jack point easily, and I decided the rear diff is beefy enough for the rear. Note that the jack barely fits under the car.
Problem 2, where are the side mount points? I find those plastic pieces that seem to make no sense. I call the dealer and ask about special adapters or jacking kits... none. Okay, so jack stands right on the plastic pieces. I later find that people have fabricated their own rectangular inserts or have used hockey pucks (i don't know how this works). Release the jack and predictably the plastic mounting points deform.
Wheels come off np and I start emptying the fluid and refilling the reservoir.
Problem 3, WHERE'S THE RESEVOIR. Did minimal research, found nothing, so i conclude it is the reservoir near the front left of the engine compartment. Pump, fill, pump, fill. The reservoir does not go down. Confused I google the number on the reservoir cap to find out it it power steering fluid. What an idiot I am.
I find the correct brake fluid reservoir which is under a panel on the back right side of the engine compartment, finish bleeding the brakes, siphon out the fluid in the power steering fluid, go all the way to BMW to get the right power steering fluid cause its BMW only fuild, and finally drive away.
Lesson learned... do more research than necessary.
Now if I can only figure out a square 18" tire setup with r compounds, I'm set for the track.
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats.
      07-16-2008, 06:53 PM   #2
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
the PS fluid is just pentosin 11S...
      07-16-2008, 10:44 PM   #3
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Feel your pain, the jack points are completely retarded with those plastic inserts...
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      07-16-2008, 10:56 PM   #4
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Oops
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      07-17-2008, 12:16 AM   #5
Big Windy
Big Windy's Avatar
Drives: None
Originally Posted by skierman64 View Post
Oops
That says it all
m3post
