10-28-2018, 08:29 PM | #1 |
6586
Rep 5,305
Help? Navigation stuck
Hey guys,
I'm hoping some one can give me a clue as to what might be going on. A couple days ago my navigation got stuck on this screen and won't come out of it. Another thing that doesn't work in iDrive is anything that has to do with my iPhone. Everything else in iDrive and other presets work perfectly fine. Any help? |
10-30-2018, 12:20 PM | #2 |
Rep 1,322
Have you done any navigation hacks to iDrive that could have caused it?
Assuming normal tricks for reset haven't worked (battery disconnect?), one thing I could think of would be to try to force an idrive software upgrade over usb stick using a download from https://www.bmw.com/en/footer/software-updates.html If you already happen to have the latest version, then maybe this won't work. If not, I'm thinking this could force a reset. |
10-30-2018, 02:52 PM | #3 | |
6586
Rep 5,305
10-30-2018, 04:04 PM | #4 | |
6586
Rep 5,305
10-30-2018, 05:00 PM | #5 |
Rep 1,322
Hmm.... did you have the stick inserted prior to powering on the ignition? If done this way, I think the update should start itself with an immediate notification that pops up on the screen after you hit Start. (Though I could be confusing that with the manual map usb update process).
If that doesn't work, then maybe you already have the latest version and therefore can't upgrade. The only other thing I could think of, other than trip to dealer, would be to see if someone on here has a copy of the previous version .bin file they could send you (sorry, I don't have one) |
10-30-2018, 07:38 PM | #6 |
Rep 1,322
.... in looking to see whether our cars have a hard reset, I found some things to suggest that perhaps holding the radio on/off (volume) button in for 20-30 sec may accomplish a hard reset. In older models, it also looks like another sequence is holding that button + eject for 30 sec.
Something worth trying if all else fails |
10-30-2018, 07:44 PM | #7 | |
6586
Rep 5,305
01-07-2024, 10:34 AM | #10 |
6586
Rep 5,305
02-06-2024, 08:47 PM | #11 |
I want to drive a Zamboni
1135
Rep 5,562
Drives: 13 E93 M3 18 F80 M3 16 K71
My idrive just went blank on me might have to take it in to have Dealer check it out, car been sitting idle for a while only 13K miles it's FY18 M3.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
