07-08-2008, 09:54 PM | #1 |
Rep 22
custom turbo
so I've decided im going to do a custom turboon my 2.5. so im looking for a turbo manifold for an m54 engine and someone who can do custom programming in the va area. anyone got any suggestions???
07-09-2008, 12:47 PM | #2 |
Rep 1,689
Custom manifolds can be welded up, you're going to have to go standalone ECU.
Not only will you need an exhaust manifold, you got a whole slew of stuff you need. You sure this is such a good idea? The costs will very likely outweigh the benefits of just going with a supercharger kit.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
07-09-2008, 08:21 PM | #3 |
Rep 22
thankfully I have bunches of turbo stuff kinda laying around...turbos wastegates intercoolers. I can make my own piping and exhausts. the stand alone would be the only "costly" part of this project. but supercharger kit? I can see now I am going to have to research this some more. thanks for the info
07-10-2008, 12:38 PM | #4 | |
Rep 1,689
Keep in mind, it is by no means a small feat, especially going custom: - Fuel Injectors - Intake manifold - Exhaust manifold - turbo - downpipe - wastegate - intercooler - all associated piping - oil lines to and from turbo, drainback into oilpan, etc... and that's just the mechanical, you then need to look into electrical to HOPEFULLY use the stock ECU and have it reprogrammed. If that fails you have to go standalone and you may need a different ignition system because you might not be able to run the stock coil packs. Basically a lot of work and a lot of downtime. have you considered EES Tuning for a supercharger kit? Personally I will be going this route myself.
