XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      11-13-2018, 10:00 AM   #1
Aerospike
Drives: 2013 F20 M135i
Oil Level Indicator
Has anyone seen the Oil Level Indicator showing overfill or does it stop at max? This whole no dip stick thing is annoying. Yes, I have added the spec-ed amount for N55, but I'm just wondering if the indicator would show an overfill or if it's just designed to show max, min, and low.
      11-13-2018, 03:10 PM   #2
sayemthree
sayemthree's Avatar
602
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
I have heard you can be a qt low and it still shows full. Not enough Experience with the X 1 for me
      11-14-2018, 08:34 AM   #3
0w40X1
Drives: 2014 BMW X1 s28i M Sport
My 14 X1 s28i n20 never showed anything , but full. I assume it's fubar.
Nothing like driving a nice car without knowing the oil level......
      11-14-2018, 10:12 AM   #4
LevinBR
Drives: 2013 BMW X1 xDrive 35i
The gauge works, and shows the oil level in 1/4 increments. If you have overfilled, it will indeed show it (and for good reason). If you don't have an iDrive display, you can check the oil level in the instrument cluster.
Mine is bouncing between 3/4 and full right now. It's probably sitting right between and is within the uncertainty of the sensor.
      11-14-2018, 01:38 PM   #5
Aerospike
The gauge does work. It went from green to yellow in the iDrive screen and I got the add 1 quart message when my oil filter cap leaked.
Does it display overfill in iDrive, the cluster, or both?
      11-14-2018, 05:28 PM   #6
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
In BMW-Bosch sensor we trust!
      11-15-2018, 11:26 AM   #7
Kevman
Kevman's Avatar
Drives: 2019 BMW X3 x30i
132k miles and mine has never changed from being full. Hopefully it works and I have a great engine. Has been an awesome car!
      11-15-2018, 02:59 PM   #8
sayemthree
sayemthree's Avatar
602
Maybe next time I will change my OiL I will purposely filled it a quart low and see what It reads
      11-15-2018, 03:15 PM   #9
mreric
Drives: 2015 BMW X1
mine kind of suck , sometimes it read half and sometime is full.
      11-16-2018, 01:07 AM   #10
Chicone
Drives: 2015 X1 X35i M-SPORT
Of interest anyway on another forum website, (an easy google search will find it), there is a discussion about adding a dipstick to the N55 motor - Only one car with N55 has one, it’s the M235i racing, only 170 were built. Involves draining the oil, removing the pan, drilling/ tapping a hole, etc.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      11-17-2018, 12:27 PM   #11
0w40X1
My build was first of 2014 and s28i. Maybe your build of N20 is close to mine, since my indicator doesn't change either.
Yours s or x?
At 5k miles I changed oil, got out 4 quarts, and put in 5.
I think 5.5 would have been closer to right.
I should have at least shown 1 quart low before change.
      11-29-2018, 09:13 AM   #12
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
I'll be changing my oil (first time) on my 2014 X1 (xDrive 28i) @ 32,747 miles. I purchased two 5qt jugs at $24.06 each (Castrol European Formula 0W-40).
Anyone know how I reset the oil service counter (I don't have the iDrive)?
Also, will 5qts suffice, or does this thing take 6qts? Manual doesn't specify.. so annoying. :-(
2020 BMW X1 28i sDrive | Alpine White
Sleepless in SW Florida
      11-29-2018, 09:52 AM   #13
0w40X1
x28i with metal drain plug takes 6 quarts, and s28i with plastic plug takes 5.5 quarts.
I use a rectangular drain pan that lies flat with 2 plugs out, then, I close back up, and pour out of end into old jug, and see how much came out.
DOrtiz13.00
      11-29-2018, 06:41 PM   #14
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
Excellent information. I have the metal plug.
Did you obtain this information from a reputable source, or is this personal experience?
Why they don't list this in the owner's manual is beyond me. :-(
      12-01-2018, 10:07 AM   #15
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
Looks like I received the right oil. However, not sure if this is the correct filter. It has "Made in Mexico" printed on it and I was under the impression Mann Filter is German. :-(
Thoughts anyone?
      12-01-2018, 05:24 PM   #16
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
So the oil change was a success!! The filter fit perfectly, and everything went smoothly. HOWEVER, I starting putting back into the 5qt container what I took out, and despite spilling a little that thing had OVER 6qt in it for sure. So I put back 6.5qt and the oil reading is as follows.
I really don't think 5qt would have been enough. Unless BMW grossly overfilled it. :-(
Hope everything turns out OK. So far, she's running smooth with no issues (fingers crossed).
PS: I'd venture to say she "appears" to be running much smoother. Of course, this could very well be butt dyno or placebo effect. 🙄
      12-02-2018, 12:55 AM   #17
Gamb1t
Gamb1t's Avatar
Congratulations on your first oil change. It's really quite easy. As for oil qty, 5-6 liters is a good start. Oil draining experiences differ due to various factors....if it's on ramps vs on all four jacks vs flat on the ground or one sided jack(bad!!!) or some other setups. Also the oil filter and the housing contains quite a bit of oil too. I would err to underfill a bit and check back after a few days of driving. Overfill is worse than underfill.
DOrtiz13.00
      12-02-2018, 02:23 AM   #18
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
Thank you Gamb1t.
It was on Rhino ramps so the drain hole was positioned for maximum drainage. I also took the advise offered here and loosened the filter housing and oil cap (more oil started coming out). Additionally, I used the "measure what comes out" methodology to determine what should go in. Again, something I read here. I can safely say I put slightly less than what actually came out (I was accustomed to my MINI, and just couldn't believe all the oil she had).
The oil which came out filled an entire 5qt and 1qt jug to the rim (past the original oil markers). I spilled a little and poured about ½qt into another 5qt jug. That part had me scratching my head, so I put in 6qt and measured. The results showed a hairline below the max-line of the attached image seen here. Therefore, I and added ½qt more and this measurement (see image) is the end result (I stopped there). To be honest, this car probably had 6.6qt if I were to guess.
I maybe put in 6.4qt (if that) and I've seen a few places online and here calling for 6.1qt. In the following video, she flashes 6.1qt (she's pretty awesome, BTW). 😉
So far (fingers crossed), she's running nicely and as I mentioned before, "appears" to run/idle smoother, quieter (maybe butt dyno syndrome though). 😀
In closing, I will say next time I'll only use 6qt exactly. Kinda hard to measure how much 6 ".1qt" is from a 5qt jug. 😔
Finally, should I let some out? I'd rather be safe than sorry.
PS: I think this weekend I'll check the air filter next. I'm just under 33k miles.
      12-02-2018, 06:05 PM   #19
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
I only fill 4.8liters on my wifes X1, xdrive and oil level shows full. Rather underfill than over.
The earlier mann of were made in germany now mexico
335i e92 TPC 19Ts
DOrtiz13.00
      12-02-2018, 06:37 PM   #20
DOrtiz
DOrtiz's Avatar
Drives: BMW X1 28i
Hmmmm. I imagine BMW grossly overfilled it then. 😳
      12-03-2018, 12:21 PM   #21
mreric
Drives: 2015 BMW X1
For some reason, i put in 5qt on my xdrive 28i and still show full right after the change, after maybe 100-200 miles it shows halfway between the low and full. i added 1 more qt after that and it showed full for a while until after 3000 miles it suddenly show low.
i really would like bmw to put in the dipstick back.
      12-03-2018, 02:39 PM   #22
Sgop335
Sgop335's Avatar
Originally Posted by DOrtiz View Post
Hmmmm. I imagine BMW grossly overfilled it then. ��
Newtis reports 5.5 liter as well must be right.
335i e92 TPC 19Ts
xbimmers
