BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
EXXEL Distributions
      07-14-2008, 06:38 PM   #1
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Be careful when adding engine oil!
After the break-in service, the oil indicator was one notch above the center line. At 4400, it dropped to the lower end of the range (the lower triangle) and a message came on saying "add 1 qrt". So, I went to the dealer and picked up the quart of oil for $12. I figured it would be best to add in increments since I don't want to overfill. So, I put in 1/2 qrt, and drive. It takes 15 minutes to report oil level again, and the indicator is still sitting at where it was before with the same message on. I drive around for another 15 minutes nothing changes.
Then, I add the other 1/2 qrt. It takes another 15 minutes to report, and this time all of a sudden, the oil level is all the way at max of the allowable range (the higher triangle). Luckily no overfill message. So the first 1/2 qrt has no effect (the indicator was not bottomed out to begin with, so you can't say I had no resolution at the bottom end at that point), but the second 1/2 all of a sudden moves it from the lowest to the highest allowable. That's very precise, ha?
So, my advice is to add the damn oil in 1/4 qrt increments to make sure you don't overfill if your oil ever runs low. If you overfill, you'll need to go to the dealer, and they will probably charge you $200 for an oil change.
      07-14-2008, 06:40 PM   #2
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
Thanks much for the info Lucid!
      07-14-2008, 06:42 PM   #3
IWearScrubs
Doctor Awesome!
IWearScrubs's Avatar
Drives: M3 Sedan 6MT Jerez and Fox Red
this thread once again begs the question...
Why is there not a dipstick?
      07-14-2008, 06:51 PM   #4
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Why did you pay for the oil? Get freebies on oil all the time...
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      07-14-2008, 06:55 PM   #5
lucid
lucid's Avatar
I didn't have time to deal with finding my service guy, having him call someone downstairs, etc. I just bought it and drove to work. Not a big deal.
      07-14-2008, 07:05 PM   #6
nusevad
O! So Sour!!
nusevad's Avatar
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
THis is why a dipstick is FTW.
      07-14-2008, 07:11 PM   #7
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
thanks man!!! my oil dropped yesterday and was thinking of adding another quart even before the message shows up, but i decided to wait. thanks!
      07-14-2008, 07:16 PM   #8
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
I'm at 3400 (2200 since service) and no drop yet.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      07-14-2008, 07:30 PM   #9
SMSgt B
Germany
155
Drives: '23 M4 G83; '23 M850i
2022 BMW M4  [0.00]
When I hit 4600 miles it dropped.
      07-14-2008, 08:21 PM   #10
Dr. T
Dr. T's Avatar
Drives: 996TT
2009 E93 M3  [0.00]
2004 FX35  [0.00]
2006 Tundra  [0.00]
2003 996TT  [0.00]
2002 S2000  [0.00]
Curious, Why would you need to go to the dealer to drain off a bit of oil?
2009 E93 M3
2003 996TT
2002 S2000
2006 Tundra
2004 FX35
      07-14-2008, 08:25 PM   #11
lucid
lucid's Avatar
If you've got a way to jack up the car and crawl under it to drain oil, you're probably fine. I don't. No garage. City living. Was speaking to my kind more than anything else I guess...
That is assuming the warning would go away when oil is drained, and does not require the dealer to turn off some kind of fault code electronically.
      07-14-2008, 08:29 PM   #12
Dr. T
Dr. T's Avatar
Drives: 996TT
2009 E93 M3  [0.00]
2004 FX35  [0.00]
2006 Tundra  [0.00]
2003 996TT  [0.00]
2002 S2000  [0.00]
OK, thanks.
2009 E93 M3
2003 996TT
2002 S2000
2006 Tundra
2004 FX35
      07-14-2008, 09:25 PM   #13
lucid
lucid's Avatar
OK, thanks.
It could get messy though. I don't know if you can cleanly drain "some" oil from the pan without a whole lot coming out.
      07-14-2008, 09:40 PM   #14
Dr. T
Dr. T's Avatar
Drives: 996TT
2009 E93 M3  [0.00]
2004 FX35  [0.00]
2006 Tundra  [0.00]
2003 996TT  [0.00]
2002 S2000  [0.00]
Just don't remove the plug all the way. That or put in a Fumoto valve.
2009 E93 M3
2003 996TT
2002 S2000
2006 Tundra
2004 FX35
      07-14-2008, 09:47 PM   #15
cosmos515
cosmos515's Avatar
Drives: I find what I keeps
You guys are not so stupid to realize that the indicator says add +1 liter (not a quart) and that the oil from BMW comes in 1 quart which is 1.25 liters....I am just asking.
So when you added 1/2 a qrt and the car asked for 1 liter and then you added another 1/2 qrt, you in fact added 1.25 liters.
ps. When you go overfill you really mess up the vanos pressure unit and engines have needed replacement because of this.
"Motion does not equal progress"
"I love the smell of cosmoline in the morning"
      07-14-2008, 10:03 PM   #16
sayemthree
sayemthree's Avatar
602
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
the manual says if you add less than 1/2 a liter/qt. the i-drive cant get an accurate reading.
No Dipstick FTL!
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      07-14-2008, 10:51 PM   #17
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
Adding 1 quart will fill less than 1 liter. 1 qt(US Liq) = 0.946352 L
Check the oil container.
Also the S65 M3 engine does not use a high pressure pump for the Vanos units. The S65 M3 engine operates the compact double Vanos system at normal oil pressure. The S85 engine in the M5/6 uses a high pressure pump and system for the Vanos. Additional oil in the S65 M3 will not affect the Vanos system because it operates at normal engine pressure. More oil in the sump does not raise the system operation pressure.
Overfilling the engine can cause other problems....like leaks and oil use, and others.
      07-15-2008, 06:28 AM   #18
lucid
lucid's Avatar
The indicator did not say add 1 liter. It said add 1 qrt. And as other have mentioned, 1 qrt is not 1.25 liters.
      07-15-2008, 06:36 AM   #19
booforty
booforty's Avatar
Drives: E92 M3
2008 E92 M3  [0.00]
Who you calling a dipstick? lol
      07-15-2008, 06:57 AM   #20
rai
rai's Avatar
Drives: M3 coupe with DCT
where else can I get the oil for the M3? My jack-ass dealer didn't give me any.
This may be the lsat BMW I buy if this oil and no-dipstick becomes and issue for me. I live 40 minutes from a dealership I need extra trips there like I need a hole in the head.
      07-15-2008, 10:31 AM   #21
sayemthree
sayemthree's Avatar
602
when they overfilled mine - i noticed higher than normal oil temps , 20 minutes before I finally got an i-drive reading.
      07-15-2008, 10:38 AM   #22
southlight
Moderator / European Editor
southlight's Avatar
1545
Drives: X3M
Had a similar experience. Added half a liter with the bc reading of 1/4 over minimum and the oil level didn't change at all. But my conclusion is to wait till the indicator tells to add 1l (or 1 qrt) and then doing just that and add exactly 1l (or qrt). Otherwise you have filled up but confused the reading.
Best regards, south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
m3post
