01-04-2019, 12:27 PM | #1 |
Rep 2,370
Drives: G87 M2; E92M3 MT&DCT; M3 euro
'08+ ABS pump on '07?
I'm thinking of swapping out my bad abs pump unit, but instead of coding to the new module, am thinking of reusing the existing module.
Realoem suggests it is "bilaterally exchangeable" which I think means the pump and the module has to go together, but I've seen 335i owners use later year pumps on '06s without a problem. Will this be the case with E9x M3?
Pass me if you can.
Tags |
5df0, abs pump, failure, malfunction, swap |
