02-18-2019, 01:40 AM | #1 |
Certified Car Nut
94
Rep 458
Drives: AMG GTC + RR Velar + 640d GC
Reverse dipping mirror working intermittently
Hello All
So have a 63 plate Gran Coupe and I have noticed that while the folding mirrors work flawlessly, The reverse dipping function on the nearside only works intermittently. Is there anything I can do (a reset) or is this something more serious? Any advice greatly appreciated
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October) Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series |
02-18-2019, 12:27 PM | #4 |
Rep 909
The mirror selector switch has to be on driver's side position to start off with. Normally only the passenger side mirror tilts down as you manouver the car in reverse. When switching back to N or D gear the passenger side mirror will tilt back up. If it is not tilting down at all then the mirror adjustment selector switch is most likely NOT set to the driver's side.
Havy304.00 |
02-19-2019, 02:05 PM | #6 |
Rep 7,590
Just an FYI...the location of the mirror switch has always determined if the passenger mirror dips when the car is put in reverse since BMW started using this technology. It's become one of those BMW engineering designs you can pretty much depend to work the same way in all BMWs. Now that I've said it...watch the next generation of BMWs will no longer function this way!
{e32/e34 ~ 1988-1994} {e38/e39 ~ 1995-2003} {e53 ~ 2000-2006} {F06/F12/F13/F10/F11/F01/F02 ~ 2010-2019}
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-19-2019 at 02:11 PM.. |
02-20-2019, 06:17 AM | #8 |
Certified Car Nut
94
Rep 458
This is the issue
Sorry I should have been clearer - the switch position is on the drivers side but the tilt function (that worked fine previously) is now intermittent1
Presume the motor for the tiltfunction is failing! Oddly enugh the folding function works fine - seperate motor? Any thoughts?
02-20-2019, 02:18 PM | #9 | |
Rep 7,590
Over the decades...some have popped the mirror glass off to see if there's an obstruction (like spider webs or other debris)...and lubricating the working parts can sometimes be helpful. The motor that facilitates the mirror glass movement is in the circular area directly behind the mirror glass: https://www.newtis.info/tisv2/a/en/f...motor/1LIP3ldp -The fold-in drive of the side mirrors is located in a different location vs the movement of the mirror glass: https://www.newtis.info/tisv2/a/en/f...ive/1VnZA3LjAI 1 = Mirror housing
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
02-20-2019, 02:30 PM | #10 |
Rep 11,891
haha, the dipping mirrors typically don't break.
On my old M3, the mirrors once folded all the way forward though...lol. Took a while to figure that one out!
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
02-20-2019, 03:02 PM | #11 |
Rep 909
Speaking of folding what would you guys apply to lubricate the mirror somewhat? In winter especially the driver's side of my F32 makes quite a noise when folding in and out (cannot call it squeaking but clearly it isn't smooth and silent as should be). Would WD40 be safe? Never applied anything in that area so just wanted to hear some input.
02-20-2019, 04:57 PM | #12 | |
Rep 7,590
You can find local vendors that sell it by googling Tri Flow...or check your local bicycle shops because it is used a lot in that market for lubricating chains and cables etc.
FBMWWINS606.00 |
02-22-2019, 09:00 AM | #13 |
Rep 209
Might not be relevant, but it's not your wife moving it back to the upright position. My misses did that a few times to me back on my old e46, in that put in reverse and would then adjust the mirror back up by using the toggle and hence reset the mirror to this position the next time I put it in reverse. It wasn't until I was in the car when she went to do it that I pointed out it was by design and it was too so her hitting the kerb.
02-27-2019, 10:18 AM | #14 |
Rep 21
Ironic that I'm reading this sat in the dealers and whilst they're trying to rectify squealing brakes for me, I've also asked about a mirror dip issue.
It appears that the mirrors do not return to the position you last left them when reverting to drive from reverse, instead revert to a default position (which is annoying). This didnt happen on my F10 but does on this car. Sorry, i know it doesn't help the OP but seems to show different cars may be programmed in different ways (according to the dealer). |
