03-04-2019, 08:16 PM | #1 |
Rep 1,020
Wheel offset calculation - need help checking math
I'm looking at a set of new wheels for my F85 and need someone (or everyone) to check my math regarding offsets on the new rear wheels since they are wider than stock and I want them to sit flush without spacers.
Current stock rear wheels are 11.5" wide with offsets of +38. The wheels I am buying are 12" wide, and I'd like the outer edge of the rim to sit about 20mm outside of where the stock wheels sit. I can customize the offsets, which I need help calculating. So here's the math as I figure it: stock wheel width = 292mm width of rim from center = 292/2 = 146mm stock offset = 38mm amount of rim extending out from hub face = 146-38 = 108mm adding the 20mm to where the wheel looks flush = 128mm new wheel width = 305mm width of rim from center = 305/2 = 152.5 to get 128mm from hub face to outer edge = 152.5-128 = 24.5mm ideal offsets of 12" width wheel should be +24.5 (round to 25) Does that seem right? |
03-04-2019, 10:10 PM | #2 | |
Rep 944
Are you lowering the car? If you truly want a flush fitment when the top of the wheel sits at the fender including camber and alignment you will need to be in the et 15 range. I am been trying to find the best combo for awhile and finally found that between 10-15 et is ideal. If you are not lowering and very low that recommendation would be too aggresive. I am running a 22x12 with a 15 et
desertfox73676.00 |
03-05-2019, 06:42 AM | #3 | ||
Rep 1,020
03-06-2019, 12:58 AM | #4 |
Rep 352
Your calculations look correct. See below (Tires specs might not be exactly what you have but it gives you an idea on how much will it poke)
https://www.willtheyfit.com/index.ph...#38;offset2=25 |
03-06-2019, 11:07 AM | #5 | |
Rep 1,020
