07-26-2008, 10:23 PM | #1 |
Rep 207
Rims in 18" but wich ET ?
Hello, i want to put rims in 18" but i don't know the right ET .
I see breyton rims in 18" with 30 in front of et 35 for the rear rims cause i want to put 8.5x18/ in front of and 9.5x18 for the rear. i know that ET 38 is for the genuine rims in 17". Thanks to help me |
08-05-2008, 03:05 PM | #4 |
Rep 62
click the link:
http://www.realoem.com/bmw/select.do enter your vehicle information and you should get the following results for OEM (depending on the current OEM wheel set up): 2 LIGHT ALLOY RIM 8JX18 ET:47 02 LIGHT ALLOY RIM 81/2JX18 ET:50 thus a high offset is good for your vehicle (+40s)...to really know for sure...compare the above offsets to the new offsets at this link to determine the clearance: http://www.1010tires.com/WheelOffsetCalculator.asp |
08-05-2008, 06:12 PM | #5 |
Rep 207
ok , but i don't know wirte the field in the second link
what i have to put into the right field ? thanks on ebay i see this link : ok but these wheels are ok or not for my car The ET for rear is 30 And the ET for front is 35. http://cgi.ebay.de/Breyton-Flame-pol...3286.m14.l1318 is ok for my car Thanks for your reply |
08-08-2008, 01:25 AM | #6 |
Rep 207
what i have to pu in the correct field .
width is 8.5 or 9.5 siez of the rims ? current wheels specs : width : 8 and offset : 47mm New wheels specs : width 8 and offset 35 mm ( like see on the ebay link ) but is only for the front ? And then what says : inner clearance and outer position ? thanks Breyton says : 8.5 for front with ET 38 9.5 rear with ET 41 |
08-08-2008, 03:50 PM | #7 | |
Όλα ρόδες
760
Rep 561
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
http://www.rims-n-tires.com/rt_specs.jsp |
