03-23-2019, 03:44 PM | #1 |
Rep 279
Replacement tires for OEM RFT
Hi everyone,
I recently purchased a 2016 650xi GC and it is a fantastic car, except for the tires. The Dunlop SportMaxx RFT 20" tires are like driving on boulders, becoming almost unbearable on any road that is not Autobahn quality. I am now considering replacing them with either of the following non-RFT tires and I am hoping that some people here have had experience driving on them: 1. Falken FK510 2. Vredestein Ultrac Vorti They are considerably less in price than the two others I was considering (Michelin PS4S and the Continental ExtremeContact Sport) and almost as highly rated. Thanks for any advice you can offer. Last edited by MichaelInChicago; 03-23-2019 at 03:52 PM.. |
03-23-2019, 03:50 PM | #2 |
Rep 661
I havnt done this yet in the 6 but did switch to continental sports in my f10 5 series, can tell you difference is night and day. Only reason I have not changed the 6 is my tyres are all still above 6mm just seems a waste.
I don't recommend running a mix I tried back NRFT and front RFT is was horrible to drive. Go all at once. |
03-24-2019, 06:22 AM | #4 | |
Rep 30
03-24-2019, 10:40 AM | #6 |
Rep 122
I experienced the same problem with RFT on my 2015 650iX GC. Switched to Toyo Extensa HP II tires, never looked back. They are relatively inexpensive (approximately $1k for all 4 installed, 245/35-20 F and 275/30-20 R) and work well. Currently on a 6k road trip to AZ, CA and TX, driving through a wide range of weather conditions from a snow storm in CO to the desert of AZ; no issues so far.
03-25-2019, 03:55 AM | #7 | |
Rep 30
Yes, but many others had same problems as i had. It's a 1000€ bet. The malfunction disappeared when i put the runflats back. I hope you won't have any issues. Good luck |
03-25-2019, 06:18 AM | #8 |
Rep 279
Thanks for the responses.
I have also read that BMW tunes their suspension for the stiffer sidewalls of a RFT so I am going to keep the RFT tires on and when it comes time to replace them, choose a more recently designed RFT tire with slightly better ride comfort qualities than the Dunlops. |
03-25-2019, 09:12 AM | #9 |
Rep 209
I don't have xdrive, so can't advise on the implications. However, there are plenty of people in this forum and 5 series forums that do have xdrive and replaced with non runflats. Just pay attention to the diameter of the tyres and the guidance of 1% tolerance in rolling circumference from BMW.
What I can say from going non runflats is there car obviously rides a bit softer, didn't feel like every pebble is a 6 inch crater. I've switched out and don't intend to go back. |
03-25-2019, 09:52 AM | #10 |
Rep 742
As long as the diameter of tires front to rear is within the 1% tolerance for rolling circumference it doesn't matter to the Xdrive whether the tires are run flats or not.
03-25-2019, 12:12 PM | #11 | |
Rep 30
I only tell my experience |
03-27-2019, 05:24 AM | #12 |
Rep 279
Just spoke with the service manager at my BMW dealership, and he told me that BMW did design and adjust the suspension settings slightly in order to compensate for the stiffer sidewalls of a RFT tire.
Therefore, I would rather deal with a slightly harsher ride than to affect the original design of the car. |
03-27-2019, 01:12 PM | #13 |
Master Of My Domain
89
Rep 669
I've got a set of staggered 373's with brand new Sport Maxx tires, maybe only 500 miles on them including TPMS that I haven't posted in the classifieds yet.
I'll post them up with pictures this weekend when I get home.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
04-01-2019, 09:33 PM | #16 |
Rep 73
Drives: 2017 650i GC xDrive M Package
I put Pirelli P- Zero (PZ 4) run flats and the ride was amazing. They felt so much softer and luxury than the Dunlops. Problem is that they wore off only after 10k miles.
04-13-2019, 04:46 AM | #17 |
Rep 279
Well, I just couldn't take the incredibly rough ride and below average performance of the Dunlop RFT's, so I just ordered 4 Michelin Pilot Sport 4S tires.
As these are non-RFT, can I use one of my winter wheel/tire combos as a spare? Thanks |
04-13-2019, 01:08 PM | #19 |
Rep 209
I'm running non runflats with only gunk and a compressor as backup. Let's be honest, unless you hit something your not likely to pick up anything more than a puncture which will be reported in the idrive which gives you plenty of time to get gunk in the tyre and get to a garage. It is honestly something I don't worry about at all. In the last 25 years of driving I've had 2 punctures that needed the tyre changing. Neither of these cars had tyre pressure monitoring but even then you could feel the car pull because of the pressure difference. I've had other tyres that delaminate but they provide a vibration so you know to get them checked and sorted. The last thing I'm going to be doing is dragging around a spare tyre when it's not needed. Maybe we're just lucky in the UK.
04-14-2019, 06:47 AM | #20 |
Rep 279
Hi elvisisdog,
Which gunk/compressor do you use? Is it true that many garages will not repair a tire that has been injected due to the mess it makes when removed? Thanks. |
04-14-2019, 11:10 AM | #21 |
Rep 209
I got the mini compressor of eBay, there was a post on here about 18 months ago about it being the same part. The gunk is just the BMW part equivalent. I'm not expecting to use it as I'm more likely to just go straight to tyre place (depends on the issue). As for the tyre place not repairing, I've no idea. I had gunk in one of my runflats as it had a slow puncture and the tyre place didn't bat an eye lid about replacing the tyre.
04-14-2019, 02:56 PM | #22 |
Rep 7,590
I make sure I renew my AAA roadside assistance annually...and I also picked up a BMW tire mobility kit which has the air compressor and BMW's sealant that can be purchased separately if used or goes past its expiration date. I got it off eBay from Sun Motors (a BMW dealership with an eBay store):
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
