03-28-2019, 11:31 AM | #1 |
Rep 998
Increased emissions with odd temp gauge behavior. Bad battery?
Hi All,
This post is perhaps a bit premature as I am in the middle of trouble shooting myself but wondering if anyone else has run into these issues. After a spirited drive the other day the "increased emissions" light popped up. Conditions were about 50 degrees out and the fuel was getting low. Car seemed to warm up normally and drove perfectly fine before and after. Read the codes and had the following: Engine P3198 Engine Coolant Temperature Malfunction 2AFD relative time, plausibility 2AF9 engine coolant temp sensor Traction 5E5B switch pressed longer than 10 sec or faulty Instrument Cluster A559 power supply switched off I'm focusing on the engine codes as I believe the traction issue could be down to a painted M button I recently installed sticking a bit when pressed in and I also swapped the steering wheel at the same time and thus disconnected the battery which I'm guessing threw the instrument cluster code. Checked the coolant level (it was fine) and cleared the code to see if it was a fluke and drove it again yesterday. The code returned and I noticed the car took a very long time for the temp gauge needle to barley move. After about 10 minutes of it hardly budging it shot up very quickly right before my eyes, it then shot down just as quickly to zero. It never overheated and after the quick up and down it eventually leveled out at the normal operating temp and stayed there. Again, car seemed to drive just fine. Spoke to the previous owner who was very helpful and indicated he would sometimes see this fault until he started charging the battery after which time it disappeared. It seems like some pretty weird stuff can happen if the battery is low. Curious if anyone had every experienced the temp gauge going crazy as I described from the battery. I am currently reconditioning the battery with my CTEK to see if that fixes it. If so I will likely replace the battery.
Current: 718 GT4 6MT, F87 M2 6MT, F30 330xi, F25 xdrive35i Gone: E82 128i M-Sport, 997.2 911, B8.5 S5, 987.2 Cayman, W211 E550, E92 M3, B8.5 S4, 981 Cayman, E82 128i, E46 M3, Z4MC, Mk5 GTI VR6, MZ3R, C5 Z06, B5 S4, Volvo T-5R, Volvo 740Ti
03-28-2019, 01:06 PM | #2 |
Rep 58
The gauge is oil temp not coolant temp...No? |
03-28-2019, 01:12 PM | #3 | |
Rep 998
03-29-2019, 11:24 AM | #4 |
Rep 998
Update. Reconditioned the battery and have been charging it since Wednesday night. Drove the car today and the error remained. Temp gauge took forever to get up to 190 or so but never quite reached 210 even after my 45 minute commute.
I am going to try to read the voltage when driving to see if it is where it needs to be. Should I just be picking up a new thermostat and/or coolant sensor at this point? |
03-29-2019, 11:57 AM | #5 |
Rep 977
I think thermostat is the likely candidate for this. FCP has the Mahle ones for 30 bucks. Or you can pay 100 for BMW.
https://www.fcpeuro.com/products/bmw...m6-11537836155
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
03-29-2019, 12:12 PM | #6 | |
Rep 998
03-29-2019, 12:19 PM | #7 | |
Rep 977
https://www.fcpeuro.com/products/bmw...-11517838201kt
