04-03-2019, 04:42 PM | #1 |
Rep 277
Program adaptive headlight
Had a headlight go out, replaced it and had dealer program it. Tried to polish the other side to make them identical but that didn't work.
Ordered a new one for the driver side today, if I get the headlight and swap over all the ballast, bulb holder, bulbs and leveler from the old headlight, do I still need to program it? Or only need programming if I'm going with a new leveling system? |
04-03-2019, 05:26 PM | #2 |
Rep 55
I've done both. I've replaced a ballast with a used one for ebay it later got wet again from a puddle and then bought a brand new headlight both worked without requiring any programming. So you should be good.
04-03-2019, 05:46 PM | #3 |
Rep 277
Ballast I think is universal for our headlights. I believe it's the leveler that needs programming.
04-08-2019, 12:58 PM | #4 |
Rep 192
Sorry to butt in your post but I had a similar issue with my Lowbeam headlight recently going out, I replaced the bulb assuming that was it but still not working on the passenger side, Does replacing just the low beam require programming as well to function properly?
12 135i: DINAN S3, ARM 7" FMIC, MADDAD MIDPIPES, REMUS EXHAUST, INJEN INTAKE, ARM CP
04-09-2019, 06:15 PM | #5 | |
Rep 277
I would assume somethings up but I'd take it in just to be sure. |
04-09-2019, 07:45 PM | #6 |
Rep 69
I actually just ordered new adaptive headlights for my 135i. I will be replacing the entire headlights on both sides. Will the headlights at least work without programming? I may have to figure out the programming later...
04-09-2019, 11:59 PM | #7 |
Rep 367
I replaced both my headlights and didn't have to program anything. Also pulled one out and fixed it again no programming required.
04-10-2019, 11:05 AM | #8 | ||
Rep 277
Do you have adaptive headlights? Usually that's the only think that needs to be programmed otherwise they'll be pointing in diffident directions. |
08-12-2019, 02:13 PM | #9 | |
Rep 893
Drives: 135is :) 192/586
Is this what you mean by pointing in different directions? If so, do you know the specifics regarding the coding? Any help would be great. Thanks |
10-12-2020, 01:46 PM | #10 | |
Rep 466
Thanks.
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV |
10-14-2020, 03:16 AM | #11 |
Rep 893
Nope. I did not bother because I wanted to have the adaptive stuff gone to begin with. Just more complicated stuff to go wrong. I'll probably try to figure it out when I have the time and potentially extra $ to burn (just in case something goes wrong).
I'm sure if I had coded right away, this likely would not have happened. I assumed it was plug and play. Just to be safe, buy 100% new modules that are meant for US cars. IDK if there are specific part numbers for it. |
