04-21-2019, 04:37 PM | #1 |
Rep 709
Seatbelt warning Gong
Hi everyone,
Just a quick question. I noticed that I don’t have that warning gong when I am not using my seatbelt. This is not normal, or? |
04-22-2019, 04:45 AM | #4 |
Rep 709
04-23-2019, 03:38 PM | #6 | |
Rep 582
Front Seat belt chimes/ reminders removal (option to code the driver or passenger's seat or both) Initial triple-gong removal (sounds after engine start if driver's seat belt is not already on) Close mirrors + windows + sunroof through Comfort Access - closing works by holding finger on groves area on handle Close/ open mirrors + windows + sunroof through Key Fob - hold down open or close key + reduced folding delay to 0.5 second Electronics off when the engine is shut off and driver's door opened Doors unlock when turning the engine off = single pull Fog lights on when car is unlocked (Welcome Lights - light switch must be on Auto: to the left) Fog lights stay on with high beams Tilt Passenger Mirror further down when R is engaged down when R is engaged Removed front windows roll-up interruption when door is opened Brake force flashing display for the rear tail lights + 3rd top brake light (only under hard deceleration and blinking stops when the cars stops) Taillights on with DRL Automatic High Beam Assist Headlights ON by default Enabled (glare free) No Dazzle High Beam Assistance Close trunk from driver side button + FOB PSI/ Temp readings under Menu > Vehicle Info > Vehicle Status > TPM Removed start up iDrive + rear CAM legal disclaimers DVD in motion USB port Movie Files playback (mp4 avi ogg vcd an xvid) + playback in motion Enabled Route Magnet (the feature works when navigating towards a destination, select Route > Alternative Routes from the left hand side vertical menu) Transfer paired-cellphone ringtone to speakers instead of generic BMW ringtone ///M Performance animation during iDrive boot-up sequence (///M cars have it by default, otherwise replace the BMW or BMW Connected Drive logo) Activate Blind Spot Detection at 17 (shows 20) instead of 40 mph The A/C button now remembers its last setting Removed rear windows roll-up interruption Increased rain sensor sensitivity for all 3 positions for Auto Wipers Digital speed in instrument cluster - press button on left stalk to cycle through date/ mileage left on HUD_TLC_ENABLE/ ave speed/ ave consumption/ digital speed Turn Signals in HUD Lane Departure in HUD Heated/ Ventilated/ Active (if equipped) remember their last setting Ability to turn on the Side cams up to 80 mph |
04-23-2019, 04:25 PM | #8 |
Rep 7,584
Wait...we (those of us in the USA and Japan) can code on and get the Euro version of high beam assist despite having the S8S4A Decoding variable light distribution (which handcuffs all the tricks the headlights do in Europe)? I thought it hadn't been hacked yet. Hmmm.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-23-2019, 07:17 PM | #9 | |
Rep 582
04-24-2019, 08:10 AM | #10 | |
Rep 7,584
From the BMW TIS in regards to the non glare high beam assist:
