04-26-2019, 09:31 PM | #1 |
Rep 280
H&R sport e90 review
I'm probably a little late to this party but I thought I'd share my experience with everyone about my H&R sport springs on my 2011 e90 on non-edc struts. My car has about 74k miles on the stock suspension and I've had it since about 60k miles. I enjoyed the way the car rode before and didn't want to dive into coilovers yet although that's been my go to in the past. I did the install myself and it took me about 2 hours. I also modified the front strut mounts and used E36 bump stops as per the advice of previous threads I read.
The install is easy if you've ever done springs before and modifying the strut mounts is also pretty Straight forward with a grinder,air compressor and a micrometer. I also installed ECS tuning extended lug bolts and 13mm rear/15mm front spacers with 25535r19 275/35R19 PSS. First impression I was very impressed with the ride quality! It's slightly stiffer than stock but I believe that most people who don't drive it every day wouldn't tell the difference. There was a little rubbing over large dips but that's since disappeared. I have about 1000miles on them now and now that they've settled the drop is about 1 1/4" front and rear. The stance is absolutely perfect! I have fallen in love all over again with the look of the car! Because of how good it looks I'm actually considering just replacing the struts and shocks when the time comes.
2011 e90 M3 DCT - Current
07 335i Stella *sold* 97 328i Lola *sold* 95 325is *sold* 93 nissan 240sx KA-T *sold* |
04-27-2019, 10:09 AM | #3 |
Rep 217
So simple, yet so perfect!
Is the trim around your windows, including the pillars separating the doors, painted black? I always thought these pieces were matte black. Last edited by drivetolive; 04-27-2019 at 10:14 AM.. |
04-27-2019, 12:25 PM | #4 |
Rep 1,881
Some are gloss black, my 2011 e90m3 also has gloss black around the windows amd pillar trims.
04-27-2019, 01:11 PM | #5 |
Rep 1,036
Both of mine have gloss black pillars / trim.
Btw OP, drop looks perfect!!
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
04-27-2019, 07:20 PM | #7 |
Rep 1,036
Mines an 08
drivetolive89.00 |
04-27-2019, 07:34 PM | #8 |
Save the manuals!
6035
Rep 6,754
Looks great! It's by far the best non-coilover suspension mod you can do on these cars. I still can't believe springs + these supplemental modifications actually work: no issues with shock travel, no rough ride quality, just a tight stiffer and feels more dialed in as it should've been from the factory.
Never before has a springs + stock shock combo ever rode well on any BMW I've had. I love it.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
04-28-2019, 08:09 AM | #9 |
Rep 280
Thanks! The trim is gloss all the way around and I guess I never noticed it was any different than any other M3... Now I'm curious where that change happened!
drivetolive89.00 |
04-28-2019, 08:28 AM | #10 | |
Rep 280
6ixSpd6034.50 |
04-28-2019, 08:45 AM | #11 |
Save the manuals!
6035
Rep 6,754
The gloss black trim was an option known as "High Gloss Shadowline" on both E90/E92. Standard trim is matte black.
04-28-2019, 08:49 AM | #12 | |
Rep 957
04-28-2019, 03:08 PM | #13 |
Rep 364
Do you rub? I've seen a mark on my rear sidewall with these springs and no spacers. Perhaps I had a full cabin...
I am thinking about a 12fr/10r spacers, but fearful of rubbing.
2011.75 E90 M3 ZCP, 6sp, Interlagos Blue
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG |
04-29-2019, 01:08 PM | #14 | |
Rep 280
My passenger rear has rubbed a couple times but it's certainly not consistent and I know has more to do with running the 13mm spacer and 275 rear tire than the springs. I love the way the set up looks too much to change it so I may end up slightly rolling the fender if it persists or becomes worse. I haven't run the car full of adults mainly because I have two car seats in the back but 1 adult and a toddler in the driver rear position didn't cause a noticeable increase in rub.
Drifter2090913.50 |
04-30-2019, 10:47 AM | #16 |
Rep 280
From what I have read there's no need to make any modifications to the rear with just springs because of the amount of travel already available in the stock shocks. I did not measure the rod length before and after the spring install.
05-07-2019, 09:54 AM | #17 |
Rep 2,091
Looks amazing! I just picked up a set if H&R springs for my non edc E90 M3 as well, I also just picked up the E36 bump stops after reading that thread last week.
I was worried it wouldn't be low enough but after seeing your post it looks perfect! Did you end up deleting the rear rubber pad as well? I was thinking of skipping that step. I am also planning 18f 15r spacers, I have 245/265 on my 220m
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
BlueKitana92463.00 |
05-07-2019, 11:55 AM | #18 | |
Rep 280
05-07-2019, 12:03 PM | #19 | |
Rep 2,091
That's funny! I had KW V2's on my E92 that were very low and my girlfriend hated it, she told me not to ruin the new one haha
05-07-2019, 02:54 PM | #20 |
Rep 10,685
I recommend the deansbimmer flat panel undertray to go with the H&R Sport springs. It will restore the clearance taken away by the shorter springs.
05-24-2019, 12:10 AM | #21 |
Rep 280
I've put a few more miles on and still love these springs. I sprung () for some new tires as well recently and had a chance to get some pictures in the daylight-ish. Pictures were taken about 12 hours and 50 miles apart. I kept the same size 275/35r19-255/35r19 fitment but went with Pirelli P Zero to replace my Pilot Super Sports. Tires have been great so far!
Drifter2090913.50 BlueKitana92463.00 |
