05-02-2019, 07:04 PM | #1 |
Rep 103
Replacement factory rod bearings?
My '08 just hit the 100k milestone, and to celebrate I'm getting her some new rod bearings. I've talked with three reputable shops in my area and have received some pretty wide-ranging quotes for the job, so I'd love some input as I decide which way to go.
One very well-known shop gave me what I consider a decent price for BE bearings + BE-ARP bolts. A second shop assured me that since I don't regularly track the car and have no plans to go FI, that I'd be fine to go with factory bearings...the price for this option is fantastic, significantly cheaper than I expected. The third shop quoted me about $1k more than I expected for treated factory bearings...so they're pretty much out of the running on cost alone. I've searched the forums, but didn't turn up much in the way of opinions on factory replacement rod bearings. Has anyone gone this route? Is it a reasonable path forward, or should I just spend the extra cash and go BE? Appreciate any insight you guys can lay on me! |
05-02-2019, 07:39 PM | #2 |
Rep 12,738
this shop doesn't understand the nature of the problem. if they are way underbidding, they probably don't understand the amount of work involved.
Instagram; @roastbeefmike
05-02-2019, 08:32 PM | #3 |
Save the manuals!
6035
Rep 6,754
A quick search would tell you *WHY* the factory bearings are a problem. Thus, it would directly allow one to infer that replacing them with the same does absolutely nothing to address it.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
Siajoon1862.50 SYT_Shadow11517.00 |
05-02-2019, 08:42 PM | #4 |
///M
237
Rep 703
Don't replace it with the factory stuff. BE + ARP bolts and call it a day.
Follow me on IG: dre.pt
donnyblaze1181.50 SYT_Shadow11517.00 |
05-02-2019, 08:44 PM | #5 |
Rep 103
05-02-2019, 08:45 PM | #6 |
Rep 103
05-03-2019, 09:51 AM | #7 |
BimmerPost Supporting Vendor
3784
Rep 2,918
Drives: 2011 E93 M3
It's not a job to give the lowest bidding shop. That's asking for problems. It may seem like a straight forward "parts swapping" type job but at our shop we get cars in every month that other "reputable" shops have screwed up.
Pick a shop that can discuss the issue with intelligence, experience, and specific examples. Do your homework here, there are literally thousands of posts on the subject. Use BE, ACL, or other bearing that addresses the clearance issues. Read about the core issue and options at https://www.bebearings.com/Overview.html |
SYT_Shadow11517.00 gfisher99287.00 |
