05-05-2019, 03:33 PM | #1 |
Rep 102
bootmod log - misfire
hey there,
Noob question: I try to understand a log. can someone please explain me how to understand a log. today i got in every run misfires and i want to see why and whats wrong. http://www.bootmod3.net/log?id=5ccf09cac090c64dbb3d00e8 Where i can see timing in zylinder 8 ? thanks for help !! Last edited by His4; 05-06-2019 at 09:21 AM.. |
05-06-2019, 09:18 AM | #2 | |
Rep 201
05-06-2019, 09:22 AM | #3 | |
Rep 102
i changed all NGK spark plugs to .022" gap and all coils. check now the Link: http://www.bootmod3.net/log?id=5ccf09cac090c64dbb3d00e8 |
carlitosgomesm5225.50 |
05-06-2019, 09:31 AM | #4 | |
Rep 201
I am unsure myself how to read the logs so can't help you much, it does seem though that there was 1 knock and that is usually not good but i don't know how common those are sorry. You could try and open a support ticket too. What OST map are you running? |
05-06-2019, 09:33 AM | #5 | |
Rep 102
ye i will open a support ticket |
05-06-2019, 09:37 AM | #6 |
Rep 201
Cool, if its a custom HCP map you could reach out to HCP i would assume that they would be able to help. You could also load a different stage 2 tune and see if the same misfires are happening, if not it could be the tune.
05-06-2019, 09:39 AM | #7 | |
Rep 102
I tryed other maps. But the issues is still there. Maybe someone can see the problem in the log. Do you know, where i can see the timing for zylinder 8 ? |
05-06-2019, 09:42 AM | #8 |
Rep 201
Sorry no idea but if that is happening to every map you tried then it could be an issue with cylynder 8, perhaps bad spark plug. Does the BM3 show you any error codes?
05-06-2019, 09:43 AM | #9 | |
Rep 102
But problem stil there. Hmm :-/ |
05-06-2019, 09:48 AM | #10 | |
Rep 201
http://ricksfreeautorepairadvice.com...-plug-threads/ |
05-06-2019, 09:58 AM | #11 | ||
Rep 102
05-06-2019, 10:01 AM | #12 |
Rep 201
05-06-2019, 02:33 PM | #17 |
Rep 102
05-06-2019, 07:55 PM | #19 |
Rep 201
