05-08-2019, 10:22 PM | #1 |
Rep 1,030
Best Conservative Drop Springs for ZCP
What are the best spring options if I'm looking for a conservative drop and are close to stock zcp spring rates?
05-09-2019, 01:16 PM | #6 |
Rep 2,712
05-09-2019, 02:31 PM | #7 |
Rep 1,030
05-09-2019, 03:00 PM | #8 |
Rep 2,712
05-09-2019, 05:29 PM | #9 |
Rep 1,030
05-09-2019, 05:38 PM | #10 |
Rep 2,712
I've been to Vegas a million times, but never been to a single EDC event.
I have heard plenty of stories where kids have fainted due to dehydration, died from from drug/alcohol overdose, and the usual medical issues associated with massive music events. The positives do outweigh the negatives, and it hasn't stopped a few of my friends and colleagues from attending every year. |
05-09-2019, 05:48 PM | #11 |
Rep 143
I can chime in about edc, I went last year in 2018. Expect long traffic lines to the event give or take 2hours just to get into the venue. Lineup was way better last year, but regardless edc isn't a event to miss out highly recommend going at least once in your life.
FriedPiston1976.50 thecarsavant35.50 |
05-12-2019, 02:27 PM | #13 | |
Rep 655
FriedPiston1976.50 |
05-15-2019, 07:47 AM | #15 |
Rep 71
05-16-2019, 11:15 PM | #17 |
Rookie
54
Rep 213
Zero issues. I was on the fence about V1 and V2's, I ended up going with the V2's on my 18 ZCP with 12mm spacers in front, 10 in the rear. It sits so perfect and the ride is softer and more livable than the ZCP Springs.
2018 M3CS SMB
05-23-2019, 10:51 AM | #18 |
Rep 3,152
are you in chet?
05-23-2019, 06:40 PM | #20 |
Rep 3,549
The Eibach spring rates average 5% stiffer front and rear over F8x base springs and 10% softer in the front, 4% softer in the rear than the ZCP springs.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-23-2019, 10:19 PM | #21 |
Rep 518
The "wheel rate" (the bit that matters) was stiffened more in the rear with the ZCP than it is in the front compared to the base M3/M4. The Eibach's maintain a similar front to rear wheel rate ratio as the ZCP but slightly softer.
We tend to think that a stiffer wheel rate means the car potentially handles better but in fact, softer increases tyre grip providing the increased body roll doesn't induce too much positive camber and overload the outside of the tyre. I've found with the M4 ZCP, the slightly softer Eibach's with the lowered ride height is faster than the stock ZCP setup particularly on bumpy corners and in efficiency mode, the car is slightly more comfortable. The ratio change stiffening the wheel rate more in the rear increases oversteer or reduces understeer and Eibach's maintaining the ZCP ratio provides the same handling balance with potentially better tyre grip. I don't know what the handling balance is like with the V2's rear ride height lower than the V1's but a lower rear ride height induces understeer that the V1's reduce. IMHO the V2's make the car look like it's still too high in the front like they are stock and the V1's provide the best stance aesthetically and reduce understeer without the need to add too much negative camber in the front. The V2's are a USA thing that isn't used by Eibach globally and I don't see why USA found a necessity for V2 with the same car distributed worldwide This is V1 with CS wheels and 10mm spacers |
Geez334.50 |
