05-15-2019, 03:58 PM | #1 |
Rep 19
Burned cable
Need help identifying whats that burned cable for, battery died and car wont even start even with triple A coming to jump start it.
Car is a 2014 X5 msport
In the garage voiding more warranty....
05-15-2019, 04:42 PM | #2 |
Rep 494
Some X5's had serious fires, never fully explained, that started in the battery area.
Suggested action: don't just get the cable repaired, do get a capable BMW SA look into this matter, they may even replace some stuff that could have caused the fire, without telling you. |
05-15-2019, 08:29 PM | #4 |
<3 Flat Four
217
Rep 754
that is very interesting, where exactly are these connections? those yellow things are butt connectors used to crimp 2 wires together. looks like all those wires were cut and spliced together before. i could be wrong but i doubt OEM wiring from the factor is done this way.
ps: ur battery is also not original, what is the history of the car?
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
05-15-2019, 09:12 PM | #5 | |
Rep 317
05-15-2019, 10:04 PM | #6 |
<3 Flat Four
217
Rep 754
i got curious and looked up butt connector ratings. all of them lists voltage ratings only (600V max) and the 1 n only place that has the current rating of 4 gauged sized butt connectors lists them as 48 amps max... and the one ur using is being used on a fuse that has a rating of 125 amps. also i suspect that burned wire either powers the starter, or something electrical hungry like the power steering unit.
05-15-2019, 10:14 PM | #7 |
Rep 2,995
Ah yes. How could I not notice the butt connectors?
You definitely need to get rid of those butt connectors. Or leave them as is and solder them together. |
05-16-2019, 12:38 AM | #9 |
Rep 317
Maverik2594151.50 |
