05-27-2019, 02:22 PM | #1 |
Rep 117
At 40-60 MPH strange vibration and noise
2013 X1 x2.8 with 65k miles. Well maintained. Aftermarket wheels been on for some time.
When driving on freeway once I hit above 40mph, I start 'hearing' what seems to be a low thumping sound (think helicopter but very low frequency thump) plus car feels like its vibrating. It's not the wheels/tires, had those re-balanced and they are perfect. It feels like its coming from below my butt and back. Car has never been abused. Zero engine codes or any codes as per Carly adapter & Carly App. Feels mechanical in nature, but I'm at a complete loss. Any ideas before I go to Dealer and have them try to figure it out? It's not undriveable, but it is bad enough to where you are afraid to go past 69mph with the vibrating you feel and the 'muffled'thumping you feel. Help! |
05-27-2019, 09:42 PM | #2 |
Rep 485
Try moving back tires straight to front.
The traction control is very sensitive to larger tires on front or back. I put ceramic brakes on back of my s28i to be less grabby. Also, grippy Michelins PS4S helped a lot. Check all the half shaft drives by hand for looseness. |
05-28-2019, 06:23 AM | #3 | |
Rep 117
05-28-2019, 12:01 PM | #4 |
Rep 443
Drives: 2021 X3 M40i (times 2)
Does it go away when you drive faster? I have had a few tires that got bulges in them on the inside where you couldn't see it, and that was generally the cause of the "whomp whomp whomp" noise. It would seem to lessen the faster I was going.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights, 50th anniv badges
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
05-29-2019, 07:34 AM | #6 |
Rep 117
The car has been taken to every scheduled maintenance interval as per CPO warranty. Vehicle only has 65k on it. Its a 2013. As far as I know, the diff probably (because I have no way to know at this moment) has not been changed.
05-29-2019, 07:36 AM | #7 | |
Rep 117
Balance was a bit off, but drove right after and and the problem still persisted |
05-29-2019, 09:25 AM | #8 |
Rep 485
What I meant is that xmodels are very sensitive to the wear of tires which can make one of same size slightly smaller.
It can throw off the traction control, and make front gear box whine. |
05-29-2019, 10:46 AM | #9 | |
Rep 98
i changed mine. no more whines and noises |
05-29-2019, 04:45 PM | #10 | |
Rep 117
05-29-2019, 04:55 PM | #11 |
Rep 117
05-29-2019, 07:52 PM | #12 |
Rep 485
I'd be very surprised if a diff will give that kind of vibration.
Years ago this would be a drive shaft problem on cars with a solid rear axle. I changed diff oil at about 5k miles to see if any metal shavings. It looked like new oil. I think it could be lifetime oil, but got my Mobil 75w90 in it. |
05-30-2019, 06:04 PM | #13 |
Rep 117
small update
Car has been in dealer for over 24 hours, Service advisor texted he is working on the estimates to give me tomorrow morning. Somehow I have a feeling it's going to hurt... oh well. We shall see.
05-31-2019, 08:35 AM | #14 |
Rep 117
another update
Well of course my CPO warranty expired in April (slapping forehead)...
Transfer case ok, tranny, ok. Rear brakes need replacing and on rear frozen caliper. So those are getting done. As for vibration, they suspect a bend in the wheels. They will roadforce balance and also do an alignment. Will let you know after all that if the problem disappears for good. Somehow not holding my breath. Seems like it's time for a new lease and no more ownership for me. |
