06-05-2019, 08:12 AM | #1 |
Rep 1,074
Wheel studs and spacers question
Hi guys
The M3 I bought came with stud kit. I’m running m359 wheels and have just added spacers 12mm and 10mm. I’m not sure if the studs are long enough to be safe. Basically after installing spacers I can get the nuts on about 11-12 full rotations. Pretty much the remainder of the stud thread is covered by the nut. Any advice would be appreciated. |
06-05-2019, 11:37 PM | #2 |
Rep 105
as long as you bought the correct length and install it right your good.. i bought my studs from apex and if you are putting no more than 12mm spacer they recommend you getting the 75mm studs but if your putting 15mm or more in the future then you need the 90mm spacer
06-06-2019, 11:12 AM | #6 |
Rep 1,036
This is correct. Unused threads beyond the nut don't do anything. Can you attach a pic?
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
06-07-2019, 09:42 AM | #8 |
Derbo Tuning
3613
Rep 3,031
thats plenty.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
