M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      06-13-2019, 10:12 AM   #1
rene316
Drives: 2013 BMW M5 F10
Need "Clutch Stop" please help!
I want to replace the factory clutch stop for my 2013 M5 F10 (Manual 6-speed) but I am having trouble finding a fit online. Any suggestions or recommendations?
      06-13-2019, 02:10 PM   #2
Chauncey.Bishop
Big girls don't cry.
Chauncey.Bishop's Avatar
India
125
Drives: E46 M3
Clutch stop or clutch delay valve?
I've been wanting to do the clutch delay valve for a while now, I just haven't gotten around to ordering it.
2003 E46 M3 COUPE - With "bolt-ons"
      06-13-2019, 02:15 PM   #3
rene316
The clutch stop. I want a thicker one so I won't have to press on the clutch all the way down. Making it a better ride, at least for my legs.
      06-14-2019, 07:02 AM   #4
technician117
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Have you searched under 550i? The early F10 models could be had with a 6 speed. I have not researched this. The pedal travel is a bit much but I think I've become used to it. I don't think it affects my shift speed.
Re: CDV delete - I just did this 2 weeks ago. You don't need to buy anything. There is plenty of room/free play in the rubber hose to simply disconnect and remove the CDV and reconnect the hose directly. The fittings are the same. If you are just doing that and not replacing the rubber hose like I had to (it was seeping from the upper compression joint) then this is like a 10 minute job plus bleeding.
      06-14-2019, 02:14 PM   #5
TLK
TLK's Avatar
112
Drives: '14 M5 CP, '12 550i, '04 545i
Clutch stop was a popular item for the E36 M3. It screwed right into where the stock one was mounted. No idea if this works on F10.
m5post
