07-31-2019, 01:57 PM | #3 |
Bored all the time
382
Rep 2,173
Plus, it's in the manual. I lowered mine, the other day... also made it a little softer.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
07-31-2019, 10:01 PM | #6 |
Rep 1,893
Drives: M5 CS / iX 50i
No. All you would have to do is remove the plastic spacers (C-clips) and use the spanner tool to lower it down to the bottom height. Both front and rear should be adjusted equally. You should not just lower the rears without lowering the fronts
See our discounted BMW models here: https://docs.google.com/spreadsheets...OBuq9ee5ZhiOA/ https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com |
08-03-2019, 11:16 AM | #7 |
Dishonorable Discharged
100
Rep 181
The C-Clip might be held too tight with the lower adjuster, back it down a 1/2 turn and see if the Clip comes out easily. Make sure to loosen the set screw in the bottom adjuster first.
