08-28-2019, 10:55 AM | #1 |
Rep 24
Start-stop bizzare issue
hi all,
first of all i hate start-stop, so i knock if off along with pressing the start button most often. on the rare occasion that it doesn't happen, i have sometimes experienced this bizarre issue: When i stop at a traffic light etc, the engine sometimes stops, as normal. later when i press the accelerator the engine starts, as expected. but sometimes as the engine starts the gear indicator changes from D to P and the engine just revs up!! (and a few annoying honks would follow ) this is either intermittent or only happens when the the engine had been in the stopped-state for perhaps 20 secs or so.. firstly, has anyone else faced this issue? secondly, any suggestions? thx j |
08-28-2019, 11:38 AM | #2 |
Rep 7,588
Wow...never have experienced anything like that. Just to rule it out...it is not happening due to accidental pressing of the P button on the gear "joystick", right (like if you're resting your hand on the joystick)?
I have no recommendation other than perhaps this is one that your local BMW dealership should take a look at...hopefully it's not difficult to replicate so that they can actually see what happens. Here's a link to the TIS that discusses the functions of MSA (engine auto start/stop). Read through it to see if anything jumps out at you in regards to what may be causing the issue. There's a list of causes under the heading SWITCH-OFF inhibiters near the bottom of the page: https://www.newtis.info/tisv2/a/en/f...ction/F7qErV2j BTW, how old is your car's battery? Low voltage is one of the things listed under switch-off inhibiters.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-28-2019 at 11:54 AM.. |
08-28-2019, 12:59 PM | #3 | |
Rep 2,926
08-28-2019, 02:01 PM | #4 |
Rep 661
Jay get it coded off, i have mine set to last position. so if i turn it off it stays off forever until i turn back on
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff |
08-29-2019, 03:27 AM | #5 |
Rep 24
Thanks Qsilver7, no chance I hit P (or anything else) by accident, I have gone to the level of observing how the D changes to P as the engine starts. That was a good read. all this time i thought this might be a software glitch (and is it?). reading through i wonder if its some fault with the Hydraulic impulse storage which seems to allow the engine to start whilst in D.
Opie55 you're correct, remembering the start-stop disable came in circa 2014. not available in mine unfortunately. mine's 2011. MARKPRIOR i've tried to code this off too (more so because i hate start-stop) below are the codes i looked for, in FEB_BODY: TCM_MSA_DEFAULT_OFF TCM_MSA_MEMORY is that correct? But the FEM_BODY module is not available in my car. possibly cos its a 2011. Is there a software reset procedure on these cars? worth a try if there is i think.. Last edited by jay.nana777; 08-29-2019 at 05:28 AM.. |
