09-02-2019, 01:43 PM | #1 |
Rep 1,304
DCT Loud First and Reserve Gear
Recently I noticed my DCT is quite loud when I put it into either first and/or reserve gear. The usual mechanical noise it makes is quite pronounce compared to before, especially when the car is hot. Other than the noise is louder the car shifts fine.
Anyone know what the issue could be? Low fluid? |
09-02-2019, 11:29 PM | #2 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
I'd say engine and/or trans mounts. Engine mounts get worn most often.
09-03-2019, 12:49 AM | #3 | |
Rep 1,304
Any way to check the trans mount without taking it out? Also come to the think of it, I don't think I will be low on trans fluid. I took the car into the dealer a month ago when I had some random DCT fault codes. They checked everything over transmission related and found nothing. They even noted on the work order there is no signs of oil leaks. |
09-03-2019, 06:30 AM | #4 | ||
Rep 558
09-03-2019, 06:25 PM | #5 |
Rep 1,304
Hmm I called a local BMW indy. They quoted $1000 to change dct fluid and filter, they'll also inspect the mounts, flex disc and center support bearing.
The dealer quoted $1300 and it includes a new pan. My brother in law works there. I can request for him to work on my car and he will also check out the mounts, flex disc and center support bearing. As crazy as this sounds, I think I'm gonna take it to the dealer for this one. $300 more but I get a new pan and a courtesy car. The courtesy car is actually huge deal for me. I always have to stress for rides whenever I take my cars to an indy shop. This one for particular only opens Mon to Fri. which makes it even harder to arrange for rides. No ride share where I live either. |
09-03-2019, 09:00 PM | #6 | |
Lord Scrip
1823
Rep 3,018
09-04-2019, 03:20 PM | #7 | |
Rep 1,304
