10-01-2019, 07:19 PM | #1 |
Rep 93
Cracked wheels
I have been driving for 40 years; never once encountered a cracked wheel. This past weekend, I found another cracked wheel (that makes 2) on the 2010 135i convertible I bought last year. Am I just having a run of bad luck or is this not all that unusual?
'18 VW Passat GT
'12 Volvo C70 T5 Inscription '05 MINI Cooper S '87 VW Cabriolet |
10-01-2019, 07:32 PM | #2 |
Bergspyder
1488
Rep 1,217
Had my share of BMW cracked wheels. At least they don't fail catastrophically.
10-02-2019, 07:15 AM | #3 | |
Rep 187
How did you discover they were cracked? |
10-02-2019, 07:42 AM | #4 |
1Addict
3243
Rep 7,910
Cracked a few wheels on this car. Bad roads here. Prompted my decision to put Apex wheels on the car. We'll see how those do.
10-02-2019, 04:47 PM | #5 |
Wolfsburg to Munich
76
Rep 294
Stress cracks or impacts? I also have a Cabrio and cracked up a few wheels in the NYC area. I’ve since changed to the 225 profile front from the 3 series, keep a close eye on my pressures and the road ahead of me. Things have been going better. I once got a blowout and as I was merging to get off the road, got another one. This was in June in Long Island and the potholes were huge.
10-02-2019, 04:49 PM | #6 | |
1Addict
3243
Rep 7,910
10-02-2019, 08:31 PM | #7 | |
Rep 93
I found the first one (rear) when I took it to a tire store to figure out why the tire kept losing air pressure. I found the second one (front) when I switched out a wheel with curb marks with one that had been freshly refinished. It had not been losing air pressure.
'18 VW Passat GT
10-02-2019, 08:32 PM | #8 | |
Rep 93
'18 VW Passat GT
10-02-2019, 08:44 PM | #9 |
Wolfsburg to Munich
76
Rep 294
10-03-2019, 12:22 PM | #10 |
1Addict
3243
Rep 7,910
Fair. But 215/40 vs 225/40 is pretty negligible difference and will be less than even the tread depth on partly worn tires.
10-03-2019, 02:43 PM | #11 |
Rep 154
I have two sets of wheels with cracks.
My 18" wheels have a small crack in one wheel which does not leak. I blame the run flat tires. I bought a set of 17" wheels used, which look good but I discovered a tiny crack in one of them also. Again, it does not leak. I don't know the history of the used wheels, but I suspect they had run flats on them in the past. This run flat idea is the dumbest thing ever. The problem of BMW wheels cracking is widespread and well known. |
10-03-2019, 06:48 PM | #12 |
Rep 93
It must only be well known about recent models. Over the years I have owned E12, E28, E34, E36, Z3 (x2), E90, E46 and now E88. The E90 started out with 17" wheels and run-flats that were replaced with 18" wheels with run-flats. This car is the only one that has had a cracked wheel problem.
'18 VW Passat GT
10-03-2019, 06:56 PM | #13 | |
European Editor
10633
Rep 22,992
Yep, mostly on BMW's built in the last ten years. More so a problem with the three series but a few one series as well. Check your wells guys. I would also recommend to replace your wheel bolts. Especially if your track or autocross your car. Dack
