10-31-2019, 04:29 PM | #1 |
BimmerPost Supporting Vendor
9607
Rep 10,891
IND | Future Classic E9X M3 Reinforced Trailing Arm Set
Amidst all of the suspension components available for the E9X M3 today, there is one that has gone overlooked—the stamped steel trailing arm. Over time, this arm has been known to fatigue and bend, especially under hard cornering or suspension compression. Consequently, the arm can buckle without warning which can be, at the very least, inconvenient or downright devastating. Future Classic's trailing arm set beefs up the OE arms by adding a dimpled, CNC machined steel reinforcement plate to the open end. By doing so, they have effectively create a box—this increases the rigidity of the trailing arm and thereby reduces unwanted flex. And, as an arm susceptible to bending, committing to steel further prevents deformation under weight, force, or heat versus any aluminum counterpart. Each trailing arm set is beautifully finished in semi-gloss black powder coat to match the OE finish and protect against corrosion. Even further, the dimpled steel reinforcement plate is a direct mirror of the OE arm, making it a subtle yet incredibly effective mod for your E9X M3. For those seeking a complete solution with improved suspension articulation, our arms can also be optioned with our trailing link bearing set. These ball joint bearings are sealed for long life performance and are devoid of any increased NVH that you would get from a monoball solution. Product Details:
Future Classic E9X M3 Reinforced Trailing Arm Setmay be viewed at the following link to our online store: https://ind-distribution.com/product...ailing-arm-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
11-04-2019, 11:48 AM | #2 |
9607
Rep 10,891
OE trailing arm vs upgraded FC:
Just installing the arms is a really easy 30-minute installun-do four bolts and slot the new arm into place! Comparison of the OE trailing arm bushings vs the upgraded FC versions:
11-06-2019, 04:34 PM | #4 |
1771
Rep 7,653
No additional NVH with the upgraded arms or the optional bushing set.
11-07-2019, 02:06 PM | #5 |
Rep 17
Just to clarify, are those bearings/ball joints, or stiffer rubber bushings. In the original post bearing and bushing is mentioned (they look like bearing/ball joints). If they are bearings, I can now understand why preloading the suspension isn't mentioned when torquing the trailing arms.
06-17-2020, 01:37 PM | #7 |
Rep 209
Drives: 2018 X5
Yes, a bit confusing. With the bearing/ bushings optioned, is it still just bolt up?
06-30-2020, 12:39 PM | #8 | ||
9607
Rep 10,891
The optional bearing set are indeed sealed bearings; I have edited-out the original mention of bushings. Yes, easy bolt-up install.
