11-02-2019, 08:04 PM | #1 |
Rep 586
So I'm having the dreaded steering wheel shimmy, and I've searched endlessly. One question I couldn't quite find the answer to..
So I replaced one of my front tires as it got a puncture. My other passenger side tire still had 8.5/32nd out of 10/32 new. So I figured I don't need to replace. Would this difference in tread (1.5/32nd) be enough to cause vibration? Car only has 35k miles -No bends -Balanced wheels -Only shimmy's between 120KMH-128KMH. -Wheels are aftermarket, 3 piece forged vorsteiner, but obviously hubcentric etc with no play. Also wanted to mention, when I mounted the wheels, I tighten them hand tight, then torque down when I lower it... is that going to cause any issues? I figure since it's hubcentric that shouldn't matter. PFA
* 2011 M3 DCT * Built 4.4L Stroker * Gintani supercharger * Brembo GT * BBS FI * OHLINS * Nardo Grey *
11-02-2019, 10:40 PM | #2 |
Rep 1,366
Have you checked your felt undertray? If it’s super beat up it will cause steering wheel shake, mine did until I switched to a metal one
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
11-02-2019, 11:14 PM | #3 |
Rep 586
I actually don't have any undertray. Literally. All 3 pieces are completely gone. Was planning to order the Mporium undertray.
11-03-2019, 06:38 AM | #4 |
Rep 938
Drives: E90 M3
Jack up the front and check the tires for run-out. Both my fronts have flat spots and I overfill them to get rid of my shimmy.
11-03-2019, 06:39 AM | #5 |
Rep 938
Drives: E90 M3
11-03-2019, 09:49 AM | #6 |
Rep 245
11-03-2019, 10:45 AM | #7 |
Rep 586
Don't think this is the issue. Took my wheels to wheel repair shop - checked for bends and none found. Also had the wheels rebalanced 3 times (road force).
11-04-2019, 08:39 AM | #8 |
Rep 1,366
Well, regardless, I’d order it anyway cause it really is great! But it also may solve your issue
04-13-2020, 08:34 PM | #9 |
Rep 586
new undertray being installed friday! Got the mumbray motosports one
04-16-2020, 03:56 AM | #10 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
If you only hand tighten in the air that could be an issue. Use an impact driver to tighten when unweighted. Drop to the point that the tire is only touching enough to not spin when tightening with torque wrench (in other words not fully weighted).
>> This process has served me well - especially with spacers. People claim issues with spacers and I have literally never had one single issue with a spacer using the above process (plus making sure all of my hub and wheel mounting surfaces are perfectly clean and rust free).
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-17-2020 at 10:12 AM.. |
acarr6411.00 |
04-16-2020, 10:30 AM | #11 |
Derbo Tuning
3613
Rep 3,031
I like two ugh-as ugh-as tight lol
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
04-16-2020, 04:41 PM | #12 | |
Rep 1,584
I just had a customer last week who had his wheels balanced within the past month and was still having steering wheel vibration around 60-65mph, his four wheels were off by 0.75, 0.5, 0.75, and 1.00 ounces so balancing them more precisely was all he needed. Many of the usual tire shops will do a more precise balance if you ask them to, they don't every time because wheel weights start to get expensive when you consider how many a tire shop uses in a year. |
slicer2746.50 |
04-16-2020, 05:41 PM | #13 | ||
Rep 586
04-16-2020, 07:38 PM | #14 |
Derbo Tuning
3613
Rep 3,031
I had a steering vibration issue and it ended up an issue where the shop did not seat the bead correct due to the ribbed beat seat. It was very hard visibly to see the improperly seated bead. The second shop ended up pumping that sucker to 50psi with TONS of that white lube to ensure it seated properly. Roadforce originally was 45-50lbs and ended up down to 11lbs after everything was fixed.
IG:ruhrohz_m3
slicer2746.50 |
04-17-2020, 10:10 AM | #15 | |
Rep 6,734
Certain wheels (like the BBS E88) have textured beads and/or are built to a tight tolerance in bead diameter to prevent the tire from rotating on the wheel under track use. The E88 is the most challenging in this department. I always check the beads prior to install. Often people think these wheels leak but 99.9999% of the time the beads aren't properly set or the valve stems aren't tight enough.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
04-17-2020, 12:10 PM | #16 |
Rep 586
So got the car back today. Wheels weren't balanced. Front was off by 0.75 (driver) and 0.50 (passenger). Rear was also off by 0.75 on one side. 99% of the vibration is gone now.
Edit : this is the third time balancing them (previous tire shop last 2 times). Didn't realize the importance of a proper balancing guy lol
Remonster825.50 |
04-20-2020, 10:08 AM | #17 |
Rep 5,482
One thing I don't miss from running staggered tires - steering wheel shimmy.
Being able to rotate made this problem disappear for me. It's only been a bad balance one time, every other time it's just been a front tire wear issue about halfway through a tire's life.
04-20-2020, 11:16 AM | #18 | |
Rep 586
