11-07-2019, 12:33 PM | #1 |
Rep 169
Not a lot of rear winter options
With the 315/35 20” wheel I am having a hard time finding a winter set up. Kumho has one. Pirelli but they are $700 Canadian. Any hints on how to locate these.
11-07-2019, 02:38 PM | #2 |
Rep 7,590
How do you feel about minus sizing to 19" tires/wheels? You'll probably get a few more selections...and they'll probably cost less, too.
Doing a quick search of dedicated winter tires using your model/model year and 20" tires on TireRacks website...I got: (https://www.tirerack.com/tires/TireS...SortCode=60200)
Then when I entered your vehicle info at the DiscountTireDirect.com: (https://www.discounttiredirect.com/f...ult/tires/sets) ... I see:
Did you try some of the Canadian national tire store chains to see what they offer?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-07-2019, 03:11 PM | #3 |
Rep 169
I have found Toyo. Just now. Another shop called and said he had Kumho. But they don’t list a 315 rear. So maybe this guy is downsizing the width. Not a lot with this stagger.
11-07-2019, 03:56 PM | #4 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
The narrower the better for winter. Downsize to 19'' square setup - most probably rims+tyres will cost you less than 20'' tyres alone.
Freude am Fahren.
11-07-2019, 05:07 PM | #5 |
Rep 169
I was shocked at the price. $7-900 per tire for winter tires. We don’t get a lot of snow. If any. More cold. More rain. Started to consider an all season after the sticker shock of winter tires. 19”. Would that not look ridiculous. I find the 20” small
11-07-2019, 06:41 PM | #6 |
Freude am Fahren.
835
Rep 1,287
I don’t care how my car looks during the winter - all I care is safety. It will be covered in dirt and salt most of the time anyway.
CT335xi684.00 pennsiveguy3552.00 |
11-08-2019, 11:28 AM | #7 |
Rep 7,590
Also, the minus size (to a 19" wheel/tire combo) also will give you a higher tire profile which helps with some protection against winter pot holes and road surface heaving. From inside the vehicle, you'll probably like the feel of the 19" set-up.
Dedicated winter tires/wheels is more of a function over form. Kind of reminds me of some friends that wouldn't wear a hat/cap when temps are below freezing...all because they didn't like the "look". I'd rather keep my head/ears warm than worry about how I look with a knit hat or cap on.
11-08-2019, 02:33 PM | #8 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
Winter tires aren't just for snow. A soft compound gets dramatically better traction on a cold wet road.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
11-09-2019, 08:44 AM | #10 |
Rep 369
Pictures please
Current
2018 F15 M sport x35i Past 2017 GMC Sierra Denali 2017 GMC Yukon Denali 2016 GMC Yukon SLT 2015 GMC Sierra All Terrain |
11-09-2019, 09:18 AM | #11 | ||
Rep 651
19" square is real good advice for winter wheels on the X5, especially if you live in a climate with real winters, snowy conditions. If you might get snow once or twice this winter, sometimes frost and slick roads, but mostly just cold...Well, wider winter tires might be fine. But wider tires won't have the same lateral grip on wintry roads as narrower will. If looks are still important, add spacers, or different offset rear wheels, but stay with same width. (My winter set up is bored out(rear hub only) OEM E71 19x9 wheels, with factory different offsets front and rear). Works good for me, and rear wheels don't look tucked into the body. Though I might still add spacers, now that I have flares. (If you have flares, stock 19"x9" ET48 stock wheels IMHO looks like you are driving on emergency spare tires at the rear, being so far tucked in.) But better be tucked and safe, no vehicle looks good sitting in the ditch (or worse) waiting on a tow truck.. |
