BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      11-14-2019, 03:24 PM   #1
simpleM3
simpleM3's Avatar
167
Drives: 06' E46 M3 ZCP
19’ BMW M5C  [0.00]
2007 E61 530XI  [0.00]
2006 E46 M3  [0.00]
EDC/Shock Function Question
I'm im the process of reinstalling the stock EDC shocks and noticed that the rod on the shocks do not extend back out when they are compressed by hand.
I assume this is because in order for them to work properly they need to be connected to the EDC module on the car. Either that or the shocks are blown.
Thoughts or comments? Thanks
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell
03' E39 M5 | 100% Stock
      11-14-2019, 04:07 PM   #2
Ultimatemj
Ultimatemj's Avatar
Drives: 2012 E92 M3 ZCP
Just posting to get updates - I'm likely about to do the same thing, and have questions about determining how much life is left in the stockers.
'12 E92 M3 ZCP Ruby Black Metallic, BBS E88, Ohlins R/T, Eventuri, Dinan exhaust, Tune +36whp, S752 + JL Audio XD1000/5 & 12w6v3, Dinmann
      11-15-2019, 08:07 AM   #3
M_Chronos
M_Chronos's Avatar
112
Drives: BMW M3
Gas pressure is not able to overcome internal friction. Remember that the actual purpose of a shock (damper) is to have resistance to movement. Shocks are charged with gas to help with bad things that happen to the oil when internals move quickly. That gas pressure typically does not have a problem overcoming stiction of seals and valves. The only for sure way to gauge the health of your shocks is to run them on a shock dyno.
      11-15-2019, 12:08 PM   #4
simpleM3
simpleM3's Avatar
167
19’ BMW M5C  [0.00]
2006 E46 M3  [0.00]
I understand that, but im not looking to get super technical about it, however, I do appreciate you adding that.
I just need to know if I should be concerned that the shocks can be easily compressed by hand and that they don't expand back out witrhout force. I trying to avoid installing all four corners only to have to uninstall them with new shocks.
      11-15-2019, 01:07 PM   #5
M_Chronos
M_Chronos's Avatar
112
Drives: BMW M3
Wasn't shooting for super technical. Just stating where I was coming from when giving you my conclusion which is in the last sentence. I haven't handled one of these shocks recently, but typically a shock in proper working order shows force from gas pressure.
What mileage on them?
      11-15-2019, 06:01 PM   #6
simpleM3
simpleM3's Avatar
167
19’ BMW M5C  [0.00]
2006 E46 M3  [0.00]
That's exactly what I was thinking and if true, these must be blown, however they weren't when they were removed which is what's prompting the question.
75k miles
m3post
