New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      11-23-2019, 11:10 PM   #1
Go351
Drives: 2016 M4 Coupe Sakhir Orange
help with finding an ignition power source
Hi all.
can anyone help me with where to find a positive 12v ACC/ ignition power source in the engine bay or fuse box(in the engine bay)
2013 28i sdrive
many thanks
      11-24-2019, 03:00 PM   #2
scootr
scootr's Avatar
Drives: E89 Z4 3.0 6MT
Do you mean a switched 12v+ source?
      11-24-2019, 06:58 PM   #3
Go351
Yes, but not one that is on a timmer. just old school. on when i'm driving and off when car is turned off.
      11-24-2019, 10:47 PM   #4
scootr
scootr's Avatar
I'll look on mine - What's it used for?
      11-25-2019, 12:23 AM   #5
Go351
I'm connecting up a light bar with its own relay circuit. I don't want it to be left on accidentally as it will drain the battery.
I'd also love to know the pin out for the high beam lights so I can splice into that too.
      11-25-2019, 01:43 PM   #6
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
I don't think you will find a switched power source with much reserve amperage available on the circuit in the engine bay.
The fuse box under the dash is easy enough to get to. There you can put in a new fuse tap of whatever amperage you want, no need for a relay then run that into the engine bay.
      11-25-2019, 02:11 PM   #7
Go351
Thanks. I wanted to avoid having to get to the fuse box under the dash. It's a real mess in there. I have also mounted a carplay unit there so not much room to move about without having to repack everything.
I did find a location in the enginebay fuse box. Pic for reference. Hope it will help others.
This location is connected somehow to the ignition, but also cycles on /off with locking and unlocking the car. So it is affected by timmer settings. Just need to be aware.
My light bar has its own 30amp fuse and a switch which I have connected to the 40amp fuse in this location.
It's been a pain for something so simple. Bmws...
Only temporary for now. As I really want to tap into the high beam lights. Which I don't currently have the the wire I need to tap into. Also when the roof is down and even when the car is locked, using this location, the power cycles on off every 5 mins. Don't know why. So it's not a clean enough solution if you want to be certain that things won't turn on....
BTW. The other fues near by in the engine bay re either continuos 12v or 12v for 2 mins and fade slowly to 0v (even when ignition is on) The 40amp I have connected to is instant 12v and instant 0v on with ignition and key fob.
Be good if someone with some real expertise can chime in on fuse box configurations.
zpost
