12-18-2019, 11:10 AM | #1 |
BimmerPost Supporting Vendor
3555
Rep 6,798
Apex Flow Formed Wheels for BMW E90 E92 E93 M3 | Built to Perform
For over 10 years, Apex has been the go-to wheel for BMW enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips. ➡︎ Perfect fit without spacers ➡︎ Made to work with big brake kits ➡︎ 100% OEM compatibility, no extra hardware required ➡︎ Unbeatable warranty & 50% replacement program The lightest flow formed wheel we make. Also the most affordable. A deep lug recess allows for easy access for beefy impact sockets without scratching the wheel face. Available in Profile 1 (less concavity) and Profile 3 (deep concavity). The less concave profile provides increased caliper clearance on narrow applications, while the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Both profiles are available in 17”, 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently. Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in Profile 1 (less concavity), Profile 2 (medium concavity), and Profile 3 (deep concavity). Profile 1 provides increased caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide-width applications. All three profiles are available in both 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently. Gorgeous flow formed lip with I-beam spokes for reduced weight. Both the inner and outer lips are flow formed to stand up to all the abuse the street and track have to offer. The spokes of the FL-5 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. Available in Shallow, Medium, and Deep lip profiles. This maximizes spoke concavity and reduces weight on the FL-5 design. Lip size is determined by offset and width, and cannot be selected independently. Modern design with reinforced lips and I-beam spokes. Like the FL-5, the SM-10 spokes were also designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) and Profile 3 (deep concavity). The medium concavity is offered on narrow-width applications, while the deep concavity is offered on our wide-width applications. Concavity is dependent on width and offset, and cannot selected independently. The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 8.5" to 11" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment? 100% OEM Compatibility No need to change your wheel bolts, center caps, or TPMS sensors. All Apex BMW wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug bolts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120 BMW wheels use a 72.56mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black Apex center caps, but you can also snap-in your OEM BMW caps for a more OEM+ look. All Apex wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem. If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" ARC-8 clears many kits up to 355mm. Our 18" wheels clear up to 380mm, including some variants of the Brembo GT kit, which has long been the benchmark as one of the toughest brake setups to clear. Our 19" wheels clear even the 410mm BMW Carbon Ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed. Weight Optimized We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. Apex flow formed wheels are officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Additional Features Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. Lifetime Warranty All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable. Our unique Apex Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. Apex BMW Wheel Gallery Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 11-06-2023 at 03:55 PM.. |
12-18-2019, 11:11 AM | #2 |
3555
Rep 6,798
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 04:58 PM.. |
06-01-2020, 04:14 PM | #3 |
1438
Rep 2,653
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
08-31-2020, 06:45 PM | #4 |
1438
Rep 2,653
APEX Overstock Sale Too much of a good thing! Some of our wheels have been idling on our shelves for too long! In order to make more room for exciting fresh inventory, we've decided to put select wheels on sale! This will be an ongoing sale and the products will be updated every 2 weeks depending on inventory. Don't see the offset or width that you are after? Check back in a few weeks! You never know what might go on sale! Head over to our website to check out the sale now!
11-06-2020, 02:55 PM | #5 |
1438
Rep 2,653
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 11-12-2021 at 06:49 PM.. |
12-07-2020, 04:02 PM | #6 |
1438
Rep 2,653
01-04-2021, 06:58 PM | #7 |
1438
Rep 2,653
01-21-2021, 05:11 PM | #8 |
1438
Rep 2,653
02-04-2021, 05:11 PM | #9 |
1438
Rep 2,653
03-09-2021, 04:46 PM | #10 |
1438
Rep 2,653
04-06-2021, 05:30 PM | #11 |
1438
Rep 2,653
05-19-2021, 04:15 PM | #12 |
1438
Rep 2,653
07-06-2021, 05:39 PM | #13 |
1438
Rep 2,653
08-06-2021, 06:46 PM | #14 |
1438
Rep 2,653
10-07-2021, 02:43 PM | #15 |
1438
Rep 2,653
Chassis Specific Fitments We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free, and hub centric wheel packages for everything from showroom-fresh cars to all-out race builds. All APEX wheels are made to work perfectly with your OEM hardware and BMW roundel center caps. F: 18x8.5" ET35 with 235/40-18 tires R: 18x10.5" ET22 with 275/35-18 tires
11-19-2021, 06:38 PM | #16 |
1438
Rep 2,653
12-08-2021, 01:37 PM | #17 |
3555
Rep 6,798
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got! If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
12-17-2021, 05:23 PM | #18 |
1438
Rep 2,653
In stock and Ready to Ship! Our production team has been hard at work this year getting our shelves stacked high with inventory for the Holiday season. In stock Flow Formed fitments for all 5x120mm BMW chassis are available. Checkout our site and order your set today! F/R: 18x10" ET25 w/ 285/30-18 RE-7rR tires Added negative camber front/rear
01-13-2022, 02:28 PM | #19 |
1438
Rep 2,653
BMW F82 M4 with 19" SM-10 Wheels in Anthracite The Flow Formed SM-10 packs high end features typically found only on Forged wheels. Knurled beading, a tough inner lip, I beam spokes and impressive brake clearance make the SM-10 an unparalleled value. Most fitments are in stock and ready to ship today! F: 19x10 ET25 w/ 275/30-19 R: 19x11" ET44 w/305/30-19 Tires: Michelin PS4S
4 Doors1169.00 |
02-10-2022, 12:04 PM | #20 |
1438
Rep 2,653
It's Group Buy Season! Don't miss out on your chance to save big on 17" ARC-8s, 18" ARC-8 and EC-7, and 19" SM-10 BMW fitments. Hit the link below to learn more: Click Here to Join Specs: Front - 18x9.5" ET22 and 275/35-18 tires Rear - 18x11" ET44 with 305/35-18 tires Tires - Nitto NT01
06-06-2022, 05:55 PM | #21 |
1438
Rep 2,653
We have a limited supply of specific tire sizes in stock and ready to ship! If you are interested in any of the tire options listed below, please email expert@apexraceparts.com with “Tire Discount” as part of the email subject. We can provide additional discounts on wheel and tire packages with these tire sizes or in some cases we can make a one-time exception to our standard ordering rules and ship tires without wheels! Please reach out for package and shipping quotes if you’re interested. Nitto NT01 235/40-17 Nitto NT01 255/40-17 We are not able to order any tires that are currently out of stock on our website. This offer does not apply to tire fitments outside of the above list. We have JRZ Suspension packages on sale, in stock, and ready to ship at stellar pricing for a handful of BMW chassis. This is an awesome chance to upgrade your suspension and dramatically improve the performance of your BMW, while avoiding the typical long lead times. Our entire inventory is shown below. All kits are in stock and on sale anywhere from $400 to $600 off: BMW E36 - 1 left in stock! JRZ RS TWO Double Adjustable BMW E46 - 1 left in stock! JRZ RS PRO Double Adjustable Remote Reservoir BMW E9X 3 Series - 1 left in stock! JRZ RS ONE Single Adjustable BMW E8X 1 Series - 1 left in stock! JRZ RS ONE Single Adjustable BMW F3X 3 & 4 Series - 1 left in stock! JRZ RS TWO Double Adjustable BMW F22 2 Series- 1 left in stock! JRZ RS TWO Double Adjustable If you're interested in purchasing a set, send in an email to expert@apexraceparts.com to get in touch or configure your kit on our suspension page.
03-10-2023, 05:47 PM | #22 |
3555
Rep 6,798
APEX | Tax Season Sale: Up to 20% off + Free Shipping* on our most popular designs.
Tax Season Sale Put that refund to work with our Tax Season Sale ongoing now. Save up to 20% off + Free Shipping* on a huge variety of in-stock fitments. Buy Now APEX Flow Formed: Up to 20% off Our most popular wheels. Our original Flow Formed classic ARC-8 and EC-7 wheels and Evolution line SM-10 and FL-5 designs are all heavily represented in this sale. Every diameter we currently produce and a wide array of sizes and offsets are discounted bringing even more value to our most affordable wheel lines. Buy Now Ready to Ship The majority of these wheels are in stock and ready to ship. With No APEX Flow Formed Group Buys scheduled for the first half of 2023, don’t miss this chance to lock in a deep discount with free shipping*. Get your wheels on the way now to make track day planning and tire sourcing easier than ever. Fitment Guides We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. Not the wheels you’re looking for? We’re kicking off Tax Season with a bang. Click here to view our ongoing Sprint Line Forged Group Buys. *Free Shipping to the 48 Contiguous States only. Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
