12-26-2019, 11:59 PM | #1 |
Rep 234
Eibach Pro springs E92 M3
Hey guys
Just needed some input. I have a E92 M3 Comp. I purchased the Eibach Pro Sport springs. Was only going to use the front as the back is already lowered by factory. The mechanic scared me into saying that I'll will feel every bump and that my suspension and ball joint will break. Any input would be appreciated. |
12-27-2019, 09:12 AM | #2 |
///M Powered for Life
11510
Rep 10,342
Change mechanics
The eibach springs are a very mild drop and pretty compatible with oem shocks. The zcp suspension lowers the front and the rear, however, eibach will still lower it a tad more Lowering springs are definitely not good for your suspension, but sticking to a oem-ish spring like the eibachs is your best bet |
12-27-2019, 10:02 AM | #3 | |
Rep 234
12-29-2019, 01:55 PM | #4 |
Save the manuals!
6035
Rep 6,754
Follow this write up and you'll have zero regrets: https://www.m3post.com/forums/showthread.php?t=423572
And get a new mechanic.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-29-2019, 07:44 PM | #5 | ||
Rep 234
12-29-2019, 07:46 PM | #6 |
Rep 234
I've been trying to see a pic of ZCP vs Eibach Pro.
What is the drop difference? I've searched the forums but no dice Just wanted to determine if it's worth paying to install the a Eibach vs keeping the ZCP springs |
