01-01-2020, 01:35 AM | #1 |
Rep 586
Sparkplug Replacement...
First of all, the CBS on the car and the recommended repairs via the dealer when scanning your key, are the most confusing system I have had with any BMW, this is my 4th BMW and I am getting a little frustrated....
Anyway, I recently had some service done (trailer hitch) and they noted that I was coming up on a brake flush and diff fluid swap. I had the dealership fix the trailer hitch module and brake fluid flush and figured I would do the diff. After some research, I realized the diff fluid swap is completely different than any "normal" car. Over Xmas I was near a BMW dealership and had them to the diff service. When I first met with them, they said that my car didn't need any service. I told them, I had just been at a previous dealership and they provided me a printout that I was due for a brake fluid flush and diff service. The SA said when the dealership resets items like "oil change, micro filter, etc...it resets all of the service regardless if it was done or not. (Sounds stupid to me, but I knew I needed the diff service, so the dealership was happy to oblige. The SA told me that my next scheduled service is in about 3000 miles and at that time I should replace the sparkplugs, air filter, and micro filter. My air filters look great and I had just replaced the micro filter, so I am good there. However, I am planning on doing the plugs myself. (Closest Dealer is 10 hours away). I asked how often the plugs are supposed to be replaced, the SA said every 35k miles. I am currently at 45k and it shows that I am still on my original plugs...?! 1). What is the recommended plug change interval? (If it is 35k, why is the SA saying I don't need them til 48k?) 2). Why would the first dealership not mention anything about plugs being needed in the near future? 3). I can't find any walkthroughs on plug replacements, is it pretty straight forward? 4). Any recommendations on who to buy the plugs from? I am OCD on maintenance and just want to treat the car right. However, there are too many items you can't even reset on your own (sparkplugs, micro filter, air filter, diff service, etc...) Any advice? Car currently has 45k miles on it. Every now and then the rpms drop a small amount when cold at start up, but nothing major (yet). I tried to purchase a service manual but can't seem to find one. I scheduled maintenance interval chart would be great, rather then CBS warnings that don't cover half of the scheduled maintenance items. Thanks in advance! Jake
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
01-01-2020, 06:54 AM | #2 |
IG: @88jae88
1624
Rep 1,742
Sounds like the guys in your area are on bath salts and they just so happen to work @ the local dealership 😂.. I could imagine your frustration because I got frustrated reading that.
IM POOR..
01-01-2020, 07:53 AM | #3 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
335i10180.00 |
01-01-2020, 11:54 AM | #4 | ||
Rep 631
01-01-2020, 07:33 PM | #5 |
Rep 1,434
I would say the OEM are also great , I think a lot of people went with the NGK’s cause they were a cheaper alternative to the OEM. Can’t go wrong with either!!
335i10180.00 |
01-01-2020, 09:14 PM | #6 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
335i10180.00 |
01-01-2020, 09:32 PM | #7 |
Rep 644
Not sure on why the first dealer didn't mention; may have been looking to just do it so you don't worry about it.
I'm at 29k miles right now, mine were done at 20k under the maintenance upgrade plan I paid for. Cost me $100 for the upgraded plan instead of like $700 without it! Car drove much stronger right after.
2017 X5M, Donnington Grey, Aragon Brown
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3 21" Vossen VFS-1 on Michelin PSS |
01-02-2020, 12:01 AM | #8 | ||||||
Rep 586
2021 Mercedes G550
01-09-2020, 09:49 PM | #11 |
Rep 199
Was in the process of getting a DME stage 2 tune and dp's when my guy said I needed new spark plugs. Currently at 35k miles. He said totally normal and should be done right around 30k mikes for these vehicles.
excu6me on Instagram.
OEM X6M Build |
335i10180.00 |
01-26-2020, 12:37 AM | #12 |
Rep 586
Installed mine today without issue. Pretty much the same as the 50i write up, except I didn't use any u-joints for the rachet, just a flex head.
Both of the rear plugs are the hardest to get to. Passenger side you need to remove the cowling and cabin air filter. I recommend running a rope through the top of the coils, they pop right out. My plugs were in good shape, I think they must have been changed once before. Overall took about 1.5hrs. It is really self-explanatory. Just make sure you align the coil packs when you reseat them. You do have to remove the aux coolant bracket to get access to one of the plugs. You don't need to remove or disconnect the tank. Overall went very smooth. I would call this a 2 job.
2021 Mercedes G550
CT335xi684.00 |
01-26-2020, 01:28 AM | #13 | |
Rep 69
01-26-2020, 11:42 PM | #14 | ||
Rep 586
2021 Mercedes G550
01-29-2020, 08:13 PM | #16 |
Rep 586
I am guessing they are all gapped correctly, but no harm in double checking them. Mine were all good and I didn't need to make any adjustments to the gaps.
2021 Mercedes G550
03-01-2021, 08:51 PM | #17 |
Rep 308
What's up? anyone ever get to bottom of this thread.. looking to change plugs but can't find any good info on forum or google.. gap? Actual ngk part numbers? If anyone actually running with bm3 tunes?
03-01-2021, 10:22 PM | #18 |
Rep 1,340
Slickrick2211.00 sly1types431.50 |
03-02-2021, 07:50 AM | #19 |
Rep 308
He's showing u more of how to get it done which is a very good video but I need more info on what people r actually running tunes not tuned, gap sizes, oem or replacements..
03-02-2021, 02:45 PM | #20 | |
Rep 503
2018 X5M- Black Sapphire Edition
03-02-2021, 05:12 PM | #21 |
Rep 308
https://bootmod3.atlassian.net/wiki/...+and+which+gap
This is from bm3 unsure if it's for our s63tu motor as people do state that there is difference from a f10 to x5m s63tu which I don't believe is right |
03-03-2021, 07:09 AM | #22 |
Rep 8
My 17 X5M was at dealer getting both rear air bags replaced under warranty. Has 37k miles. I asked my BMW service rep if Spark plugs need replacing, as service manual says 30k. He told me he looked at the key for the vehicle and it was not due spark plugs (it would cost $780!). he said the car will alert me when needed as it is based on driving. He said usually around 45k-50k based on driving habits. I am pretty sure my car was owned by a older person that did not drive it hard. Is this accurate the car will tell me when spark plugs are due?
I will DIY when I should do them, does not look like a hard job. Thanks! |
