01-17-2020, 02:47 PM | #1 |
Rep 709
Parking brake malfunction in display
I have an issue with the Parking brake. I got the message “parking brake is not working “ A few times the message just disappeared after locking the car but now it’s on all the time. What kind of problem could it be?
01-17-2020, 06:20 PM | #2 |
Rep 2,926
Step one is to determine if it is actually not working or if you are just getting a false message. The parking brake, because it is two electric motors - one on each rear wheel - it quite audible when it is applied in a quiet place. In a garage with the ignition on and your radio and blower off, apply the brake and listen for the sound of motors whirring for about a second and a half.
01-18-2020, 03:25 AM | #3 |
Rep 709
Thank you. I will check and report after.
Edit: Yes, the electric motors are working fine. I put the battery recharge on. Maybe that will help as the battery voltage was quite low. Last edited by Havy; 01-18-2020 at 08:50 AM.. Reason: After the test. |
