02-01-2020, 11:41 PM | #1 |
Rep 64
Coil overs
Question please. Was wanting to lower my 2016 X5M this spring. Thinking coil overs. But can I do coil overs only in the front and use the air suspension adjusted lower in the back? Or do I need coil overs on the front and back? Confused. Thanks for the input!
02-02-2020, 03:12 AM | #2 |
Rep 364
Drives: M2C X5M M4
I'm not a modding guy as I like stock but I've driven X5's with low air is rear suspension and they drive badly. Also think you will damage the bags but as I said I've never done this mod and I'm sure someone with a load more experience will be along soon
02-02-2020, 06:12 AM | #3 |
Rep 271
All of the suspension kits whether just lowering springs or coilovers lower the rear by replacing the stock linkage to the height sensor with a different length to trick the system.
hatmandew6.50 daytonaviolet1254.50 |
02-02-2020, 09:41 AM | #4 | |
Rep 64
02-02-2020, 10:22 AM | #5 |
Rep 271
Look at what comes with a KW kit...coilovers for the front, dampers for the rear, and adjustable linkages for the rear ride height
Chipmunk2k314.50 |
02-02-2020, 10:25 AM | #6 | |
Rep 64
02-03-2020, 07:53 PM | #7 |
Rep 340
I have a set if your interested. Was on the car for about 5k miles and car got totaled due to hydrolock. Let me know. I will add pictures on my for sale threat tomorrow.
'12 MW E92 M3 I Piano Black Trim I Vorsteiner Aero Front Lip I Varis Rear Diffuser I Varis Rear Skirt I Platte Forme Side Skirt I Ohlin's Road and Track Coilover I Akrapovic GT4 X-pipe I Akrapovic Slip I ESS Tuning I Brembos Brakes I Euro Front Bumper I BBS Limited Black Edition Lugs/Locks I Macht Schnell Studs I BMW Performance Carbon Fiber Spoiler I BMW Performance Grills/Gills I BMW Performance Seats I Rogue Short Shifter I BBS FI
02-15-2020, 06:59 AM | #10 |
Rep 631
Phara, I'm sure you've shared before but what is your drop and settings on the KWs? Plan to get mine installed in the next couple of weeks.
02-23-2020, 02:58 PM | #11 | ||
Rep 64
02-24-2020, 01:32 AM | #12 |
Rep 631
Quick install question. I was at 30" in the rear after about an hour of driving. A couple days later, 29.5". Should I be concerned about my air bags?
Edit: down to 28.5". Is it ok to drove if my bags are shot? |
02-24-2020, 07:18 AM | #13 |
Rep 64
It could be the bags are leaking or just a bad sensor. I would take it to the shop to get looked at.
02-24-2020, 08:00 AM | #14 | |
Rep 631
02-24-2020, 11:15 AM | #15 |
Rep 944
02-24-2020, 01:50 PM | #17 |
Rep 364
Drives: M2C X5M M4
If it is the bags don't leave it too long as the compressor will suffer, there only a plastic piston ring and will become tired quickly if overworked
02-24-2020, 02:11 PM | #18 | |||
Rep 64
[IMG][/IMG] |
02-24-2020, 02:24 PM | #20 |
Rep 64
I lowered 2" front and 1.75 in rear. It was hard to find too much info on it but stumbled across them and then spoke with a rep at Modbargins and he also recommended them.
